Reading Inputs of a Stamp PLC
Hi I've just started working with the Stamp PLC (Stamp BS2 installed).
Everthing is very easy, except reading the first digital 8 Input lines.
I got the example to work. But I need to read each point and check to see if it is·on/off.
I tried to use VAR.BIT1 thinking I could read each bit of the word gotten via the SHIFTIN command. But that·does not work.
Any thoughts would be welcomed
Thanks. Blaine
Thanks. Blaine
· GOSUB Read_DigIns
... all of the inputs are available as aliased bits (i.e., dIn1, dIn2, ... dIn10).· Make sure you call the Read_DigIns before you access one of those variables so that you have the current state of the inputs.
Jon Williams
Dallas, TX· USA
