boe-bot and bluetooth - barcode reader — Parallax Forums
yunoyuno Posts: 5
edited 2005-05-10 21:42 in Robotics
hi my name is Yoon Oh who is currently attending to the Maryland Institute College of Art
·i bought the Boe-bot last year and i did some project with this model like avoiding the edge in
the black lined circle. and i am currently doing the project called "barcoding navigation" which is
first you make the barcode out of your name - with barcode generator program and print them
out. and scan that barcode with the USB barcode scanner then this information goes to the basic
stamp through the usb port in the computer and delievered to the EB500 which is bluetooth
module. once this bluetooth module got this information, it will send to the boebot through the pair
of EB500 and make this boe-bot move!··
i got this two bluetooth module connected and communicated, but i cannot send the data getting from the barcode reader to the other bluetooth module
i get the numbers from barcode scanner to the debug window but why i can't send the data to the other bluetooth module...
should i set up the variable that makes communicate two bluetooth module?
or is there any other specific command or word for working this??
    edited 2005-04-29 21:07
    yuno,
    ·· You should attach your code so we can see what's going on with it.· It could be something in your code.
    csavage@parallax.com
  • yunoyuno Posts: 5
    edited 2005-05-06 18:29
    sorry i will post my code today~~!!
    thanks
  • yunoyuno Posts: 5
    edited 2005-05-10 21:24
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    ' {$PORT COM7}
    temp VAR Word 'Loop counter
    szData VAR Byte(20)
    'Wait for the eb500 radio to be ready
    PAUSE 1000
    connect:
    SEROUT 1,84,[noparse][[/noparse]"con 00:0C:84:00:0D:AB",CR]
    SERIN 0,84,[noparse][[/noparse]WAIT("ACK",CR)]
    'Either an Err #<CR> or a ">" will be received
    DEBUG "connected"
    IF IN5 = 0 THEN connect
    send:
    DO
    DEBUG "which direction should i go? " ' Enter values in debug
    DEBUGIN DEC temp ' Terminal
    DEBUG "hello",CR
    SEROUT 1, 84,[noparse][[/noparse]temp]
    PAUSE 200
    LOOP
    ' this is the code that i used for one board but it not getting the point to the /debug "hello"/
    'it keep got freezing when it gets the data from debugin
  • Ryan ClarkeRyan Clarke Posts: 738
    Ahn-yang haseyo Oh-shi. Hangook saram e shin gayo?
