LM34 in 4-20 mA configuration?
Has anyone ever tried using the LM34 temperature sensor in the 4-20ma output configuration ?
I'm trying and have no luck latetly.
Just wondering if its me.
Post Edited By Moderator (Jon Williams) : 4/29/2005 12:32:06 PM GMT
·· I've never used this configuration before.· The datasheets lists an example circuit for it.· Are you using the components listed?· Including tolerances of the parts that require them?· What is happening with your circuit?
csavage@parallax.com
For example most the time I get nothing out of the circuit other times I get 139 ma, which tells me something isn't wired right.
I was just wondering if I have forgot to use a bread board or not.
Or if anyone else had problems.
If things are intermittant...check connections first!
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
