simple transistor question???
is it a bad idea to put a transitor on the positive side of a circuit
12volts+
Transistor
led--led--led--led
Ground
it seems in most designs the transistor on on the ground side...
12volts+
Transistor
led--led--led--led
Ground
·· It depends on which type of transistor is used and how much current it can handle.· In your example you would need to be using a PNP transistor, and it would require a LOW from a Stamp I/O PIN to turn it on.· Of course, you should have a 1K resistor between the base and the Stamp I/O PIN.
·· If you used an NPN transistor, the LEDs would be on the positive side of the transistor, since the emitter would be tied to ground.· In this case, a HIGH on the Stamp PIN would turn it on through the 1K resistor.· Again, the transistor needs to be able to handle the voltage and current.
csavage@parallax.com
I know nothing about Stamps (never seen one) but in the case of the PNP transistor example, the Stamp would need to pull the base down as you said. In order to be able to turn the LEDs off, the Stamp would need to be able to switch its output up to 12 Volts supply rail, or alternately, have an open collector style output.
Something to be aware of; perhaps the Stamp meets those requirements.
Peter (pjv)
·· You are correct...Some minor modifications would need to be made to handle that, which is outside the scope of this discussion.· Suffice it to say he should use the NPN transistor.
Post Edited (Chris Savage (Parallax)) : 4/29/2005 1:59:36 AM GMT
Using an NPN is far more common than using a PNP.
Is there a reason you must source the LED's?
It is possible to use a PNP, but it is not so easy using 4 LEDs. If you use 5 LEDs the attached circuit will work (I tested it).
But there is no advantage to the posted circuit. Personally, I would go with the NPN as Chris suggested.
