Which fuse to use?
·hello, I currently am working on a project that controlls several strips of LEDs via BS2. The stamp is sending signals to a ULN2803A, which is firing several relays at different times, which are conecting the LED strips to a seperate power source. I got the power source with the LEDs, and it outputs24VDC, 20W max, but I've had to connect the 120 line to it myself, via a creepy and dangerous looking plug, cut off of some old something or another. I was thinking that an in line fuse would help reduce the danger of having 120 current at exposed terminals in my enclosure. I figure if something goes wrong, then the fuse blows, and if I'm shocked, it's only for a second- much less lethal, but still... my question is about choosing the right fuse. How will I know what current is being used, and how much more than that should the fuse be rated at? Plus, I'm using a plastic enclosure, so there's no place for a chassis ground connection. What should I do with the ground wire? Would a isolation transformer help reduce the danger here. But most importantly : which fuse. Please help- I dont like fires. Thanks!
it will save your life if something goes wrong
they sell them at home-depot,
only downside is theyre build into power-outlets,
so youd have to wire the power-outlet in-line (after) your PSU, before your circuitry.
hope that helps
Second a fuse will not blow when the power is going through your body. Don't think that because you have a fuse it will be any safer in that respect. Plug your device in a GFI outlet if you want protection against that.
As for a fuse a .2 A fast acting should do the job. Measure with a meter and see what you device is using, and then pick a fuse a hair bigger. Maybe 1.2 times your actual draw.
Post Edited (Orion) : 4/29/2005 1:06:12 AM GMT
