Interface to modem
hello,
we are testing with a new modem,and in hyper teminal we give the command· "linkup s1" and then push enter.
now like we do that with a stamp and use the next line
serout 14,n9600,[noparse][[/noparse]" linkup",CR]
now we like to now is there a other instruction for the enter command.
greetings erik
Post Edited By Moderator (Chris Savage (Parallax)) : 4/27/2005 10:55:13 PM GMT
greetings erik
·· You are already doing an enter in your SEROUT command with the ',CR' at the end.· If that's not working you can try adding a ',10' after:
·· Also, in your SEROUT command, you're not putting in the s1 that you were using in the command you sent from HyperTerminal.
csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 4/27/2005 10:57:01 PM GMT
··········· You will want to find out if the modem needs a TTL(0 to 5vdc) signal or a true RS232 signal (~ +11 to ~ -11vdc). Next would be the baud rate number if you are using 8n1 at 9600. You can find you these in the stamp manual version 2.2 page 407 or also in the help file for the stamp editor in the Serout command.
Stephen Swanson
Technical Support
sswanson@parallax.com
i go try the 10 after CR
greetings erik
