BS1 Help
Hi all,
I'm working on a design project for a class using the BS1 and I'm having trouble writing the code.· Our design has seven buttons and seven LED's (one for each button) that are connected in parallel with the button.· We would like a LED to illuminate when·a button is pressed and to stay illuminated until the next button is pressed.· So at any given time, only one LED is illuminated and that LED corresponds to the button that has been pressed.··Any help·is appreciated, as I am very new to BASIC programming and to the BS1.· The code that I am using is as follows:
'{$STAMP BS1}
'{$PBASIC 1.0}
DIRS = %10000000
Main:
IF DIR1 = 0 THEN Button1
Main2:
IF DIR2 = 0 THEN Button2
Main3:
IF DIR3 = 0 THEN Button3
Main4:
IF DIR4 = 0 THEN Button4
Main5:
IF DIR5 = 0 THEN Button5
Main6:
IF DIR6 = 0 THEN Button6
Main7:
IF DIR7 = 0 THEN Button7
GOTO Main
Button1:
· IF PIN1 = 1 THEN Press1
· GOTO Main2
Button2:
· IF PIN2 = 1 THEN Press2
· GOTO Main3
Button3:
· IF PIN3 = 1 THEN Press3
· GOTO Main4
BUTTON4:
· IF PIN4 = 1 THEN Press4
· GOTO Main5
Button5:
· IF PIN5 =1 THEN Press5
· GOTO Main6
BUTTON6:
· IF PIN6 = 1 THEN Press6
· GOTO Main7
Button7:
· IF PIN7 = 1 THEN Press7
· GOTO Main
Press1:
DIRS = %11000000
HIGH 1
GOTO Main
Press2:
DIRS = %10100000
HIGH 2
GOTO Main
Press3:
DIRS = %10010000
HIGH 3
GOTO Main
Press4:
DIRS = %10001000
HIGH 4
GOTO Main
Press5:
DIRS = %10000100
HIGH 5
GOTO Main
Press6:
DIRS = %10000010
HIGH 6
GOTO Main
Press7:
DIRS = %10000001
HIGH 7
GOTO Main
Thanks for your help.
'{$STAMP BS1}
'{$PBASIC 1.0}
DIRS = %10000000
Main:
Main2:
Main3:
Main4:
Main5:
Main6:
Main7:
GOTO Main
Button1:
· GOTO Main2
Button2:
· GOTO Main3
Button3:
· GOTO Main4
BUTTON4:
· GOTO Main5
Button5:
· GOTO Main6
BUTTON6:
· GOTO Main7
Button7:
· GOTO Main
Press1:
DIRS = %11000000
HIGH 1
GOTO Main
Press2:
DIRS = %10100000
HIGH 2
GOTO Main
Press3:
DIRS = %10010000
HIGH 3
GOTO Main
Press4:
DIRS = %10001000
HIGH 4
GOTO Main
Press5:
DIRS = %10000100
HIGH 5
GOTO Main
Press6:
DIRS = %10000010
HIGH 6
GOTO Main
Press7:
DIRS = %10000001
HIGH 7
GOTO Main
Using pins as both input nd output is not easy.
Another way of doing it is to use Shift-Registers.
Connect the buttons to one parallell-in/serial-out type register, and the LEDs to a serial-in/parallel-out type register.
(See articles on expanding number or pins among the Nuts&Volts pages)
Then just SHIFTIN the button status, SHIFTOUT the same Byte to the LEDs, take a PAUSE and GOTO start...
You may want to examine the status Byte, though, particularly if it only allows for one LED to light at any time.
Have fun!
' {$STAMP BS1}
' {$PBASIC 1.0}
SYMBOL Ledstate = B1
Ledstate = %10000000
SYMBOL x = B3
Main:
DIRS = %11111111
Chk1:
x = Ledstate & %01000000
IF x = 0 THEN Off1
LOW 1
GOTO Chk2
Off1:
HIGH 1
Chk2:
x = Ledstate & %00100000
IF x = 0 THEN Off2
LOW 2
GOTO Chk3
Off2:
HIGH 2
Chk3:
x = Ledstate & %00010000
IF x = 0 THEN Off3
LOW 3
GOTO Chk4
Off3:
HIGH 3
Chk4:
x = Ledstate & %00001000
IF x = 0 THEN Off4
LOW 4
GOTO Chk5
Off4:
HIGH 4
Chk5:
x = Ledstate & %00000100
IF x = 0 THEN Off5
LOW 5
GOTO Chk6
Off5:
HIGH 5
Chk6:
x = Ledstate & %00000010
IF x = 0 THEN Off6
LOW 6
GOTO Chk7
Off6:
HIGH 6
Chk7:
x = Ledstate & %00000001
IF x = 0 THEN Off7
LOW 7
GOTO Wait
Off7:
HIGH 7
Wait:
DIRS = %10000000
CheckInputs:
IF PIN1 = 0 THEN Update1
GOTO ChkP2
Update1:
Ledstate = %11000000
GOTO ChkDne
ChkP2:
IF PIN2 = 0 THEN Update2
GOTO ChkP3
Update2:
Ledstate = %10100000
GOTO ChkDne
ChkP3:
IF PIN3 = 0 THEN Update3
GOTO ChkP4
Update3:
Ledstate = %10010000
GOTO ChkDne
ChkP4:
IF PIN4 = 0 THEN Update4
GOTO ChkP5
Update4:
Ledstate = %10001000
GOTO ChkDne
ChkP5:
IF PIN5 = 0 THEN Update5
GOTO ChkP6
Update5:
Ledstate = %10000100
GOTO ChkDne
ChkP6:
IF PIN6 = 0 THEN Update6
GOTO ChkP7
Update6:
Ledstate = %10000010
GOTO ChkDne
ChkP7:
IF PIN7 = 0 THEN Update7
GOTO ChkDne
Update7:
Ledstate = %10000001
GOTO ChkDne
ChkDne:
GOTO Main
Jon Williams
Dallas, TX· USA
