BOE bot wheels and servos
I own an older version of the BOE bot (not the current one that Parallax sells). I'm planning on buying two new servos for my bot, and I wanted to make sure that the continuous rotation servos Parallax sells will work with my wheels. I'm planning on buying 2 of these servos:
http://www.parallax.com/detail.asp?product_id=900-00008
My BOE bot wheels can be seen in the picture that is attached to this message; they have 4 curved holes in them rather than the multiple small oval-shaped holes in the new wheels. Does anyone know if the splines on the servos I gave the link to above will indeed fit with my old wheels?
Jason
Unreal tournament 2004 rox
Post Edited (DestroyerX) : 4/25/2005 10:34:03 PM GMT
Jason
· Yes, the servos will work with the older wheels.· Same brands usually use the same spline/spindle on the servo.
csavage@parallax.com
Jason
·· Yes, the servos are pretty much standard in size, so, you'll be alright.·
