RC Time (and temp)
When using RC Time, how stable is it with temp changes? I was thinking like 30 degrees up to 120 degrees or so. Is there a wide swing? Very little? I would like to build an outdoor project that will see these temp changes and wondering what·I will face if anything.
·· The stability of the RCTIME command can't be spelled out as a constant.· It will be affected by the stability of the components used at the various temperatures, including, to some degree, the BASIC Stamp Module itself.· You will simply have to test a circuit out in a given set of conditions to see what you're looking at.· And of course, using components with better tolerance ratings helps!
csavage@parallax.com
http://www.emesystems.com/BS2rct.htm
Tracy Allen
www.emesystems.com
I will do some reading and a freezer / toaster oven test
