Problem with 2 Ultra-Sonic Range Finder
I have a situation where by i need 2 ultrasonic range finder to detect 2 objects. While testing with 1 sensor the response of the sensor is very fast, however when the 2nd sensor is added in the response become slower. Is there anyway to solve this problem??
Thank You
Thank You
·· Not sure which Ultrasonic sensor you're using, but most take a finite amount of time for the echo to return and for the sensor to report the data to the Stamp.· If you're running 2 at once, and the objects were both far away, it could slow things down a bit.· Perhaps you could post your code and we could see what's going on?
csavage@parallax.com
