Beefy Source = More Current?
I'm wondering if using an 9VDC 500mA AC adaptor to my BOE Rev C·instead of a 9VDC 300mA AC adaptor will increase the total current available to output?· I'm·operating 10 servos from my board, and current becomes an issue when using more than 4 to 6 servos at once.· I was thinking about getting the servo controller, but I'm not sure if that gaurantees enough current for 10 to 16 servos at once, and at this point, if·I can fix things by switching power supplies, I'd like to try that, but I'm asking beforehand so I don't fry my stamp or something.
Denis·
Denis·
http://www.parallax.com/detail.asp?product_id=28023
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Post Edited (Dave Andreae (Parallax)) : 4/24/2005 11:14:46 PM GMT
Dave
Dave Andreae
Tech Support
www.parallax.com
If all 5 are not turning all the time, you may be able to get away with it.
For 10 servo's, you need around 2 amps to run all of them continuously. Again, the duty cycle you control the servo's with, and what's connected to them, makes a big difference. (Perhaps a TO-3 package 3 to 5 amp regulator, with a bigger wall-wart, would allow this to work.)
