i2c over draw
ive encountered a problem using the bs2p communicating with seven motor controllers·using·i2c. it·worked ok·for a short time but then stoped. after checking everything twice i eventually ran only one on·pin 8 and·9 and it worked but pin 0· no longer works. i was using 4.7k pullup resistor and the md03 motor controller. Curious if any one else was having similar problems and if they found a solution
thanks nick
thanks nick
·· Have you confirmed whether or not PIN 0 works with anything else?· For example, does it go HIGH/LOW, or report INPUTS?
csavage@parallax.com
thanks nick
·· If you can, I would get to the bottom of what may have caused the damage so it doesn't happen again.· This is why I have been stressing an added amount of caution in how to interface things to the Stamp.· Sure, many of the circuits work great when there are no problems or unforseen circumstances.· But when something does come up, you lose a Stamp pin, and that can usually be avoided by following safe guidelines.· If you need any help on connections, please post them here, and we will try to help.
