coin counter
I am a graduate student who needs help putting together a demonstration for my students.· I attempting to construct a coin sorter with an LCD ouput that outputs the sum of the change counted.· I will be using break beam sensors to detect the coins and then a program to count the coins and add the appropriate amounts to output to a serial Parralax LCD in a 4 bit mode.· I need help writing a program that will do what I need it to do.· I am a mechanical engineer, so this is all somewhat new to me.· Any help would be appreciated.
" Hey! Why is there silicone on my hemostats?"
I was working on something like this a while back....but I was more concerned with false counts and hadn't even gotten to the 'counting' stage.
You can do this any number of ways!· You can use a photo diode and detector in the same module ( http://www.katlax.com/pdf/pg_1_82.pdf·-- I just googled this real quick..but it's similar to many modules out there).
A simple LED and a photoopto will work too!· I don't know of a general output from these...but the link above shows that it'll switch V+ back to you when it's interrupted (depending on Normally Open/Closed).· The Stamp is great at reading TTL logic (+5volt and 0Volt).
I'd suggest you download the "What's a Microcontroller" text from Parallax's website to get some easy ideas on doing basic things.
You'll want to protect your stamp with an resistor in series with your sensor (Can't remember what a good value is....22k?).
You can do a search in this forum and find my old thread...but I hadn't settled on anything in particular as to how I was going to prevent a penny and a quarter from passing through the same beam...OR...a penny causing a 'count' in the quarter shoot!· I think I was leaning towards a silo type of canister with pager motors (vibrating)...in the hopes that the motors would smooth out the coins so I could guide them towards different holes.
I had also looked at the CAM type arm that the M&M sorter uses...but again, I need to deliver one coin at a time....stacking becomes an issue when you drop a handfull in.
http://web.mit.edu/~jijon/www/coinsorter.htm· this is a site of interest....I'm looking at doing something similar to this....but they only sort...not count!
I looked at weight....magnetics....colour vision....diameter....it all came down to isolating coins and characterizing them one at a time!
LEt me know how you do!!· It's rather simple..but fun and complex (didn't I just say simple?)....
cheers
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
