Ultra Bright LEDs
Does anyone know of a dealer in the US·sells bulk LEDs· lots of about 100 or so.· I need Ultra bright 10,000 MCD and above it possible.· Ive seen them on ebay but the place is located out of country and I need them pretty fast.
DB
DB
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
·and 441-1009-ND. Both are $106.60 for a lot of 100. It is much harder to determine what stock other electronics distributors carry because they do not provide parametric searches of thier inventory like digikey does.
One possible route is to get the "LED on steroids" modules like the 1 watt modules on the lower half of this page, or the Luxeon·modules. I have two Luxeon Star Side-Emitting modules and they are literally blindingly bright. These modules require constant current source drivers to get the most efficiency out of them and they are pretty pricey.
Here is an LED described as "Blindingly bright" availible for $0.42 apeice in quantities of 100 or more, but no luminous rating is provided.
the RL5-W18030 is a white LED at 18000 mcd. Cost for 100 count is $119.00.
I have dealt with these folks and have been happy with them. They're located
in St Louis, MO so middle of the country, pret' near. You didn't say what color
but they have plenty of colors and styles to choose from. Oh, the 18030's are 5-mm.
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
Tim
Express shipping ($20.00 extra) takes 2 days (to Pacific Coast). Otherwise it takes 1 to 2 weeks.
I've purchased several thousand LED's from him but I have to warn you that he can screw up your order. For instance, one time I ordered 300 LED's and he only sent 100. Never did get that resolved. He seems to be better if you order direct rather than through eBay.
If you need a lot of LED's, he seems to be the only choice (unless you don't mind paying exorbitant prices).
Kenny
Kenny Gardner
GAP Development Company
http://www.gapdev.com/
The super brite lights listed in the links above are awesome too.· Radiohead uses a similar light setup.· I can only imagine what they paid for their light show.· Those light bars nearly blinded me.
Anyone know if there is a standard for HotShoe connections on digital of film cameras?
Chris Isaacson
www.marktechopto.com/
www.nichia.com/
I've dealt with both. Their LEDs and service are both top-notch.
You might also check out the KingBright line that Mouser sells. Their P4 high-flux LEDs may fit the bill for you.
And finally, anybody who wants to know anything about LEDs dares not pass up the LED Museum:
ledmuseum.home.att.net/ledleft.htm
This is a real treasure trove of LED info, including tests and reviews. A MUST!
Good luck!
Phil
