Can anyone help me
I'm working with a project and I need to get the temperature, for this I got a LM335, so my doubt is how to convert the value to digital. I got a friend idea of using a ADC0804 but I don't have idea how to connect them and how to use them, I'm kind of newbie... hope someone can help me.... thanks
·· If you're required to use those parts, it sounds like a class project.· In that case you might want to read the datasheets on each part, and look for code examples using the ADC0804.· Basically you're going to need 8 inputs on the Stamp just for the data.· Glancing at the datasheet, this looks like you're going to have some fun.· If it weren't for your part number requirements, I would've gone with the ideas suggested previously.· Or at least used a different ADC, such as the ADC0831.· Good luck!
csavage@parallax.com
