A full plate
musictech
I have been given a full plate worth of projects to do.· All of which has to be completed in 8 days.· If anyone would like to help with any portion (especially coding), it would be greatly appreciated.· I don't have time to order much but since I am at a college, they have a lot of items on hand.· The projects are listed below:
Soccer Game Project
This project consists of an 8'x5' metal table.· Two feet above the table we have constructed a pvc platform covered underneath with aluminum screen wire.· There will be 8 or 10·sumo bots used.· All controlled by laipic 315mhz tx/rx modules that are tied into playstation 2 controllers.· The sumo's will get their power from a dc power supply tied into the metal top table and the screenwire (see bumper·boe bot post).· When a score has been made, the ball will drop through a hole at either end of the table (depending on which goal has been scored) triggering a change on a scoreboard of some type (stamp, plc, or computer controlled) and go to a box on the side of the table, to be returned to the board by the attendant.· My biggest issues here is figuring out how many stamps I will need for the controlling the scoreboard and ps2 interfaces for 8 to 10 playstation controllers, figure out the circuit for them to attach to, and the code to make everything work.· The final touches to the table itself will be finished tomorrow morning.
Robosapien Project
This project is utilizing 2 stamps to run seven motors in a Wowwee Robosapien.· We are using the L293D motor controllers (4 of them).· This one is a bit more code intensive.· Basically, all they have to do is dance together or perhaps somehow interact with one another like follow one another.· Whatever they do, it will all be preprogrammed and no actually human interaction will take place.
Tank Project
Similar to the first one in just about every detail, with one exception.· Instead of RF, we will be using infared and the communication will be two way.· The screening ·from the first one will be equipped with infared diodes and emitters.· Instead of just sumo bots, we are also using standard boebots equipped with a track system·.···There are 2 tanks (boe-bots) and 4 smaller vehicles (sumos).· The players will use ps2 controller to feed to the IR system in the top of table, to send commands to the bots.· The bots will use that data and to control its own IR system to "fire" at other tanks.· The hits will be fed back to the emitters in the top of the table and back to a stamp to control a scoreboard (once again, plc, stamp, or PC driven).· The tanks will fire slower, and move slower than the other bots, but take many hits from the smaller bots before a point is registered.· The big issue here is getting the infared in the table top to work.· I have done it with one boe-bot, but not with six bots that have up to 9 different commands and feed back data.· That and coding will be my issue.
Wish me luck, and send me some coffee
Soccer Game Project
Robosapien Project
Tank Project
Sounds like a good way to ruin a great hobby [noparse]:)[/noparse]
Work:· Clemensb@otc.edu
Good Stuff on my Blog: http://theDeadBug.journalspace.com
