Printed Circuit Boards
Hi all...
What is the new technology for desinging and laying out printed circuit boards?· When I was really into it, it was a time consuming and very messy procedure, which involved designing and laying out the board with tape and sticky symbols, transfering that design to film, photosenthesizing the copper clad board with a really nasty and·gloppy substance, transfering the image to the board with a high power UV light that constantly burned my eyes and hands, then etching the board with chromic acid...the end product was servicable but not pretty.·I know that there must be a better way now (it has been about 25 years or so) to make PCBs now using computers.· Any ideals would be most welcome!
Thanks in advance
Joe
KB0TXC
Cats are the creator's method of demonstrating to mankind that man is not the supreme being.
Thanks in advance
Joe
KB0TXC
If you want to have them done professionally, many people on the forums use www.expresspcb.com·which has a deal for 3 boards 2.5" x 3.8" for $51. They have a proprietary layout program for designing boards availible for free download on their website. These boards still have a prototype feel to them because they do not have a soldermask or silkscreen.
When I have time to wait for a board, I like to use www.sparkfun.com. They have a PCB production service for $2.50/sq in. no minimum size and has soldermask and silkscreen and can accomodate trace pitches small enough for 0.85 mm pin spacing surface mount parts. The turn around time is 10-18 days because they aggregate several customer orders and have an asian PCB manufacturer do the production. They require Gerber files.
When I do not have time to wait or I have surface mount parts with 0.50 mm pin spacing I use www.33each.com which offers 3 boards up to 60 sq. inches apeice for $99·(discounts are availible for students) and has soldermask and silkscreen. They also have in-house designers to check over your design to make sure your not making any production mistakes such as placing soldermask over pins. They too require Gerber files but will do translation from other formats such as OrCAD for you. Their turn around for this service is 5 business days, faster times are availible by using thier regular service (for more cost of course).
To create designs using Gerber file formating, I use EaglePCB from www.cadsoft.de. Thier free version does all the things the professional version does except the board size is limited to 4·x·3.2·inches and two layers.
Post Edited (Paul Baker) : 4/20/2005 2:53:50 PM GMT
Photosensitized boards are not really used that much any more, you just clean your board, apply the resist, etch, rinse, disolve the resist and rinse again.
Post Edited (Paul Baker) : 4/20/2005 3:32:23 PM GMT
Jon Williams
Dallas, TX· USA
csavage@parallax.com
Chris Isaacson
I've used this method to make a few boards and it works fine, though it's somewhat time consuming because you'll need to use a toothbrush to remove the photopaper before you can start etching. If you're in a hurry, Radio Shack still sells copper clad laminate (4.5 x 6.125 in for $4.29) and a pint of ferric chloride ethchant for $4.29. If you have the time - you can find copper clad laminate for much less online - I picked-up a 4 x 8 in x .026 inch thick piece for $.95 at www.goldmine-elec-products.com/home.asp
If you want more information - or want to learn how to design and build your own printer and etcher then check out groups.yahoo.com/group/Homebrew_PCBs/
I agree...I do not have the time or inclination to actually etch a board...I would much rather get a professionally made board with solder mask and screen printing. You have to remember that the last time that I actually made a PCB was 25 years ago, and as I said before, that was a real nasty process.
I have one question though, and I am afraid that it shows my ignorance...what is a Gerber file? I am going to look at the companies that were mentioned above, and hopefully get going on this. One other question...does one input the circuit diagram and the software design the layout or do you design the layout yourself and the software simply makes it look good and bring the spacings and such to spec?
Thanks again for taking time to answer some very basic questions!
all the best
joe
Jon Williams
Dallas, TX· USA
Chris,
·· No, ExpressPCB doesn't output to a gerber file directly.· It uses a proprietary format.· I don't know if they still do it, but it seems like you used to be able to buy the gerber file from them.· They do however offer decent prices on higher capacity production runs, so you don't necessarily need to go elsewhere.
Post Edited (Paul Baker) : 4/20/2005 6:11:06 PM GMT
I have also used pcbpro.com for production board (same company as pcbexpress). The pricing was good, but the boards weren't quite the same quality as the 4 for $100 boards. Of course they were only $2.50 each for 150 boards 1.5"x2.0", so I has happy. The main problem I had was that the solder mask had "drip" marks on some of the boards. Doesn't hurt anything...Just doesn't look too good.
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
You provide gerber, and order is online, credit card only. The web page is a little screwey, but
5 peices, 5 days turn,Specs: FR4, 0.062",1 Oz Cu., SMT pitch minimum 0.025", smallest hole 0.015", all Plated holes, smallest trace/space 0.007", Green LPI Mask, White Silkscreen, Individual boards.
Most of the time they send more than the 5 peices, usually 7 to 9 boards for $75 for the lot.
Cheapest I've found.
-Dan
www.cadint.com (U.S.)
www.cadint.se (Elsewhere)
The user interface takes some getting used to, but once you get over the hump it leaves the others in the dust productivity-wise.
For proto PCBs, I highly recommend Alberta Printed Circuits:
www.apcircuits.com
They have two-day turns and rock-bottom prices for two-sided PTH boards without soldermask or silkscreen.
In dealing with a proto house, the first thing you want to ask them is their definition of a "board". Most will not allow you to panelize more than one copy or one design on a single "board" without charging extra. Fortunately, APCircuits doesn't employ any Panelization Police, realizing (rightly) that their business is drilling holes and etching copper by the square inch -- not scrutinizing their customers' designs. I refuse to deal with any board houses who charge extra for panelized submissions.
For soldering surface mount boards, I use solder paste from DigiKey that's sold in a syringe. (Can't remember the brand.) The boards are then reflow soldered in a Panasonic NB-G100P infrared toaster oven. It works great, but -- even with the time and temp control -- you've gotta keep your eye on the board while it's in there!
When you wrote that you use a toaster oven to reflow your solder, it reminded me of when I would have to use that glopy photosensetiser on the copper clad...once we had it spread on the board, we would let it dry for an hour (in the dark of course), then put it on a cake cooling rack (small one) inside of an electric fry skillet over night to cure. The skillet was supposed to be set on the lowest setting, but sometimes a prankster would turn it all the way up, and if someone didn't check it when placing their board in there, the next morning they would really have a toasted board!
All the best,
Joe
KB0TXC
http://robotroom.com/PCB.html
My $0.02, being a progrssional at this stuff
-dave
This is not a sig. This is a duck. Quack.
· I have to agree. The board houses incure no extra expense for a multi-up board (against a board of similar size with the same # of holes). So I don't see how they can justify the extra charge. I would be like an extra charge for buying 4 of the same candy bar. It makes no sense.
Bean.
www.sxvm.com
bugg
Boe-bot: $229
Toddler: $249
Learning Google is your friend: priceless
You might want to check out the Al Williams book "Build Your Own Printed Circuit Board" (ISBN 0-07-142783-X) - great source of info, and teaches you basics of Eagle CAD.
Ryan
I know lots of professional pcb services here but I am thinking on something suitable for small series.
Harry
