spaek jet — Parallax Forums
spaek jet
JeremyJeremy Posts: 4
edited 2005-04-20 15:12 in BASIC Stamp
need help with stamp to speakjet communication
    edited 2005-04-20 13:25
    Parallax's·webpage for speakjet has a sample program http://www.parallax.com/detail.asp?product_id=30075
  • JeremyJeremy Posts: 4
    edited 2005-04-20 13:39
    does anyone know where to get a wiring schematic for speakjet to boe-bot configuration? Please
    edited 2005-04-20 13:48
    are you using the bare chip or the tigerbotics development board?
    edited 2005-04-20 13:55
    the bare chip
    we've got it working in demo mode bud it is barely audible.
    edited 2005-04-20 14:12
    Are you using the minimum connections configuration on page 3 of http://www.magnevation.com/pdfs/speakjetusermanual.pdf·? If so then use the configuration immeadiatly below titled "Minimum Connection for Serial Control." The demo mode configuration is only intended as a "make sure its working" configuration, for applications you need to amplify the sound to properly drive a speaker.
    Is speaker volume the only problem·you are having?
    edited 2005-04-20 14:14
    We have it connected to an audio amplifier and the volume control is fixed. Now we need to figure out how to wire it to the boe-bot.
    Connect pin 17 of the Speakjet to pin 14 of the stamp, and pin 10 of the Speakjet to pin 15 of the stamp and use the demo program I pointed to. You can connect pins 17 and 10 to any two IO pins of the stamp, but you will need to reflect the change in the demo program.
