electronic speed controller from an rc car
Is it possible to plug one of these where a servo would go? I've got some old rc setups that I was considering using for my projects so thats why I'm asking....
thanks,
Mark
thanks,
Mark
··········· If this is a standard RC receiver the output should be the PWM, so as long it is 0 to 5vdc pulse you will bring that right in to an I/O pin·through a 220 resistor on the stamp using the Pulsin command. I did a RC controlled BOE BOT awhile ago and was very easy after I mapped out the min and max values. So then for the speed control you would just send a pulsout.
Stephen Swanson
Technical Support
sswanson@parallax.com
Post Edited (sswanson (Parallax inc.)) : 4/20/2005 8:01:18 PM GMT
