Bubble Sort In Basic - Sorting an indexed array
Hail Board,
i'm developing a little project that requires sorting and i just wanted to share what i have developed and exchange ideas about the algorithm and code in general. the tricky thing about my bubble sort is the way i indexed data in the scratch pad.
questions, comments, advise?
here is the code:
" Hey! Why is there silicone on my hemostats?"
here is the code:
txt
1K
·· Nice job!· And no sorting in the EEPROM!· LOL· I will have to check this out in more detail later, but I think it's the first sorting routine I have seen on the BASIC Stamp.
csavage@parallax.com
there arent many applications for a bubble sort in the world of stamping. i suppose that's why it never came up. In any case i always liked the bubble sort because its a simple, easy-to-follow teaching tool for sorting even if its inefficient.
rox on
One suggestion, is that in some cases the the BUBBLE subroutine might be called when the array is already sorted, or when only one score has been added since the previous sort. In that case it there is no point in passing through the loop more than once or twice. I'd add a one bit flag variable that is set to TRUE before executing the inner loop, and set equal to FALSE if any swap takes place while passing through the inner loop. After the inner loop a test, IF noswaps THEN EXIT. Another small thing, if NOP is a constant, then NOP-2 is also a constant and a little program space and speed can be saved by also defining NOP2 CON NOP-2.
' Nick's code, slightly modified, untested! 'ax,cx are bytes for counting 'tmp_a,tmp_b,value,value2 are bytes for storage 'RANK and SCORE are constants that index locations in the scratch pad ' --- rank(0) holds index of highest score ' --- first pass through the inner loop brings the lowest score to rank(NOP-1) 'NOP is a constant for the number of players 'rank = 0 'score = 16 'NOP = 16 'swaps is a one bit flag 'the scratch pad ' 0-15 rank of player1 -> player16 ' 16-31 score of player 1 -> plater16 NOP2 CON NOP-2 BUBBLE: FOR ax = 0 TO NOP2 'outer loop counts iterations of the inner loop noswaps=1 FOR cx = 0 TO NOP2 - ax 'inner loop counts through array and tests for swaps GET RANK + cx, tmp_a 'gets the index of the cx'th ranked player GET RANK + cx + 1, tmp_b 'gets the index of the next ranked player GET SCORE + tmp_a, value 'gets the score the the cx'th ranked player GET SCORE + tmp_b, value2 'gets the score of the next player IF value < value2 THEN 'if the cx'th player's score is less than the next player's score PUT RANK + cx, tmp_b 'swap the index in the ranking PUT RANK + cx + 1, tmp_a noswaps=0 ' -- okay, there was at least one swap during inner loop ENDIF 'otherwise leave them alone NEXT IF noswaps THEN EXIT NEXT RETURNI have a median routine at www.emesystems.com/BS2math5.htm, but I think your ranked bubble sort would be a better way to go about that. I came at it in a different way, iteratively extracting the minimum and maximum from a list.
Tracy Allen
www.emesystems.com
do while (noswaps)
nexted swaping routine
loop
this would minimize the number of iterations of the swapping routine
