Bumper Boe -Bots
I have been given the task of creating a table that will support multiple boe-bots. It works essentially just like bumper cars. The ground plane is going to consist of a 8ft by 5ft long stainless steel table. The positive portion of the bumper car table will be made out of aluminum screen wire supported a couple of feet above the table by PVC pipe. (I can reverse these if I like). The idea is to run an antenna up and down and make contact with both the table and the screen and pipe them into the stamp, eliminating the need for batteries.
My question is do I need to create some sort of circuit to condition the power coming off the table or can I just use a solid wire antenna straight into the stamp?
The potential problem (pun intended) that will likely occur is voltage supply dropping out momentarily. The large caps would act as a battery for a very short period of time as the contacts bounce across the screen or the floor.
Sounds like a cool project. Please take pictures and share.
Post Edited (KenM) : 4/19/2005 7:43:36 PM GMT
You'll probably want a diode in there to insure current only goes TOWARD the BS2, as well.
