help relay question again
I have a 5 vdc RSB-5 relay that operates with a 120 ohm coil. The I/O pin will not activate it but the Vdd will. The problem with the Vdd pin is that i can not use it in my could. Any more great ideas from you poeple will be great cause i am in a bind it for my senior project that do friday. I just need to be able to operate the solnoid valve.
thanks Adam
Post Edited By Moderator (IT Guy (Parallax)) : 4/17/2005 11:28:48 PM GMT
thanks Adam
http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv6.pdf
Jon Williams
Dallas, TX· USA
Jon is correct.· The best way to design it “cleanly” is to add a buffer transistor as shown in N&V.
You may consider another “quick and dirty” fix.· If you have a few more spare I/Os on your Stamp, you may try· paralleling them together (my guess is that 3 or 4 would do it).· Not sure if you’re sourcing or sinking the relay, but generally outputs have more drive when sinking.· Therefore, connect one side of the relay coil to +5 and connect other side to the paralleled outputs (your logic will now be “active-low”; a LOW will activate relay).
Also, make absolutely sure you add the back-EMF diode across the relay coil regardless which circuit you choose.
Jim S.
Use one pin and a suitable buffer circuit to prevent damaging your BASIC Stamp.
Jon Williams
Dallas, TX· USA
