Appmods?
Are all of the appmods that deal with tcp/ip settings specific to BASIC stamp? I need a way for my computer to communicate with the stamp over some sort of IP setting through like a modem or something (ran out of pins to do a hyperterminal hook up and I can't use the terminal in the SDK because I need to interface another program with the stamp). Has anyone done this before and if so could they send me some code? Thanks!
I would guess after looking into it for a while, that the Stamp is sadly woefully in-adequate to deal with TCP/IP. There are some co-processors I found, the best being a "co-processor" from Maxim-IC (used to be Dallas Semi). The link is:
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/4535/ln/
Not sure if this is the exact item I was thinking about but its similar - have a browse on the site?!
Failing that, what about getting a secondhand RedI webserver - I think they have been discontinued now.
All in all, best stick to serial, i2c, CAN or maybe RS422/RS485 networks at best.
James
One alternative to the Redi is the Hellodevice, see thread
http://forums.parallax.com/showthread.php?p=524088
regards peter
