Unreliable programming with BS2P24
I've got a few stamps (2*BS2, 1*BS2P24). I've recently gotten a USB Board of Education, and my previosuly reliable BS2P24 fails programming the majority of the time now -- at different points in the download. Once in a while, it will actually program.
My two BS2s program just fine, so I don't think it's a USB issue, Windows problems, or BoE issue. I've even tried powering the board off both 9vdc and NiMH batteries -- but still same results.
Any thoughts? Should I just assume I've got a flakey Stamp?
-marc
-marc
Go to your "Device Manager" and click on "Ports" and find the your USB to Com port.· Then click on it and then click on the "Port Setting" tab and then click on the "Advance" button in the middle.· Find the "Latency" section and set it to 1 and then click on "okay" on the way out and see if this solves the problem?· If not, please contact Parallax's tech support at 1-888-997-8267 with your set up ready to test.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
A quick test with a couple of different programs seems to indicate that has fixed the issue. I guess that tightens up timing on the USB part of the link?
Thanks for help
-marc
