Servo Control Problem
I am VERY new in robotics with fair understanding of programming. I have spent all night tonight looking for an answer to the mystery that baffles me.
I have 3 servos which I try to control via BS2. 2 servos are used to move a single rod (I needed the torque) and therefore did a small adjustment so both servos move together without one straining the other, and the 3rd servo rotates the base accordingly. The code I wrote (don't laugh but it is something new to me) is this:
·· '·{$STAMP BS2}
·· ' {$PBASIC 2.5}
·· BottomArmPulses·· VAR· Byte
·· BasePulses······· VAR· Byte
·· counterBA········ VAR· Byte
·· counterB········· VAR· Byte
· DEBUG CLS, "Enter Arm position (0-60):", CR
· DEBUGIN DEC BottomArmPulses
···· GOSUB BottomArm
· DEBUG CLS, "Enter Base position (250-1150):", CR
· DEBUGIN DEC BasePulses
···· GOSUB BaseRotate
·· BottomArm:
·· FOR counterBA = 0 TO 20
···· PULSOUT 10, (BottomArmPulses * 15) + 250
···· 'PAUSE 20
··· ·PULSOUT 11, ((BottomArmPulses * 15) + 250) + (BottomArmPulses + 5) ' + Adjust
··· ·PAUSE 20
·· NEXT
·· RETURN
·· BaseRotate:
·· FOR counterB = 0 TO·100
·····PULSOUT 5, BasePulses······· '1150 is FAR LEFT··· 250 is FAR RIGHT· 700 is MIDDLE
··· ·PAUSE 10
·· NEXT
·· RETURN
My problem is thus:
When I remark anything that has to do with the first 2 servos (BottomArm), the 3rd servo (BaseRotate) works fine in every respect. When I try to combine both actions together, the 3rd servo always moves far clockwise (to the 250 and beyond...) and I cannot seem to get it working whatever I do concerning values.
This is probably something simple to you gurus out there but it has me baffled. I have read "What's a Microcontroller?" and information on the Internet (including of course Parallax) but could not find anything.
Is my coding wrong? (unless - which I doubt - the servo has a problem)
·· '·{$STAMP BS2}
·· ' {$PBASIC 2.5}
·· BottomArm:
···· 'PAUSE 20
··· ·PAUSE 20
·· NEXT
·· RETURN
·· BaseRotate:
··· ·PAUSE 10
·· NEXT
·· RETURN
My problem is thus:
Thus everything works until you assign to CounterBA.
Solution: Declare BasePulses as a Word.
This raises another question though...... Any idea why it works when I rem the "BottomArm" function. It should not since the values are over the 255 value..... I wonder.....
Thanks anyway. I was too tired too climb out of a pit and you were there to pull me out.
Thus, when you call BaseRotate, the low-byte is read from BasePulses, and the high-byte is still in CounterBA, so it works. When you actually call BottomArm, that routine clears the high-byte, so bad things happen after that.
Note I'm really guessing about the low-byte | high-byte thing.· It makes sense in this circumstance, given the symptoms you describe.
