Engine TACH. Mesure 5v square wave.
I plan to use a SX chip to measure the RPM of an engine. (Full size, 8cyl)
There is only one wire that needs to be monitored.
All that I have found so far is:
First off, does that circuit seem correct to you?
Next, what is the best approach, SX wise, to measure the 5v square wave coming from this wire.
The higher the RPM the faster the square wave comes in?
Does that sound right?
I don't need to display this information, just send a number via Serial.
Thanks for your input.
Jack
If it's 5V, as I suspect, you'll need a resistor, cap, and zener diode to connect in the lead between the tach output and the computer. 10000 Ohms from HEI >------/\/\/------o---------o----------------> to CPU 1/2 Watt | | | | ___/ _____ 5V Zener // \ _____ .001 uF Cap 1 W /___\ | 100V | | O---------- | ----- --- - his circuit will convert your input into a relatively clean square wave at a voltage which should be compatible with the computer. Solder the components together, insulating them from each other, and attach 3 wire leads (in, out, and ground). Heatshrink the whole thing together and wire it in series with the tach lead close to the computer, making sure it has a good ground. If the input requires some other voltage than 5V, simply use the appropriate value zener.
Jack
I have done this a handfull of times, and depending on the vehicle it can be easy or not so easy conditioning the signal.
What model vehicle will you monitor and EXACTLY where do you intend to get the tach signal from?
csavage@parallax.com
This is a custom vehicle. there is no make or model.
KenM, , the engine is a 6 liter GMC Gen III V8.
Chirs, Paul , optically isolated sound like a great idea.
I'm familiar with isolated relays, but how do I isolate a square wave?
As for the SX, should I use a timer to measure the 5v pulses?
Could I use SX/B PULSIN for this or is there a better way?
Am I right is assuming that the faster the pulses come in the faster the RPM is?
I know, nothing but questions.
I'm also reading that the tach square wave voltage could be between 4.5 to 5 volts
and is at 2 pulses per crankshaft revolution
Jack
Post Edited (PLJack) : 4/16/2005 12:14:14 AM GMT
As the engine RPM increases, so too does the frequency, or period of the tach square wave.
Even though the signal is 4.5 to 5 volts and can be read directly by the SX, it is indeed a good idea to isolate the signal, with a 4N25 for example
Thank you. That helps allot.
Using the circuit listed in my first post, I assume the 4n25
goes between the SX pin and the cap.
As an aside, did I read the specs on the 4n25 correctly, the
transfer rate is 2 microseconds!
How do they get an LED to move that fast?
Fear not.....if it does "load" the tach signal, there is an easy solution.
This circuit completly replaces the one in your original post.
oops.....the schematic should say "to SX", not "to Stamp", but you get the idea
Post Edited (KenM) : 4/16/2005 3:31:04 PM GMT
I understand and prefer your circuit.
The engine people tell me that the wire I need to measure IS the
tach signal.
Thanks again.
Jack
I ran across the type of configuration the 4N25 uses, can you explain the purpose of the conection to the base? I have always thought of optoisolators as the photodiode setting the base current of the transitor, the connection to base makes me doubt my present understanding of optoisols.
It is free.
As I understand the opto isolaotors, the LED portion does provide the base drive.
The base connection with a resistor to ground is to speed up the turn off time of the opto isolator. It discharges the base capacitance when the LED portion turns off.
Post Edited (KenM) : 4/17/2005 4:05:30 AM GMT
