SX28 X,Y plotter
Hi All,
I've been away from assembly for eight years now and recently picked up SXes for hobby with a purpose of building CNC controls for my Shoptask mill/drill/lathe. The SX (so far) takes x and y coordinates and draws straight lines between, then loads the next coordinates and draws again. I'm half way through loading an EEPROM chip with a trig table and hope to add arcs to the functionality, which would take me one step closer to taking M-and G-code inputs, though I have a hunch I am going to run out of programming space before I have every option (tool offset, acceleration/deceleration, etc.) though I believe I will end up with something workable.
The assembly code for the SX28 is attached.
I would be more than happy to explain any part of the code; my comments aren't abundant, and the handling of binary fractions in the program is a mess to solve. I am also open to programming suggestions for format, reliability or just comments in general.
I realize this project is more than likely done a hundred times over, but I wanted something to challenge myself with that I could use in the end, and say I did it.
-Ken
ps - If anyone would like code to program EEPROM with a trig table, tomorrow or the next day I will have a zero-to-45 degree table for tangentials in 0.05-degree steps, 1800 bytes. Precision is 16-bit fractional binary. Of course I tried looking on the internet for this first, but couldn't. Perhaps I can save you the time?
-Ken
If your running out of program space, you could switch to the SX48 or SX52. They have double the program memory and the code will run with just minor adjustments.
Just a couple comments on your code. (since you posted it, I assume you want feedback).
First of all, it is very nicely formatted and easy to follow.
You have a line "mov dsCount,#!15" the "!" is not a valid character here and it seems to be loading dsCount with zero ???
Instead of "$03.0", it·is usual to just use "C"
Thanks for posting it,
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
Post Edited (Bean) : 4/14/2005 12:10:45 PM GMT
