store numbers from keypad — Parallax Forums
WhipeOutWhipeOut Posts: 13
edited 2005-04-15 20:07 in BASIC Stamp
I'm working on this pin code project, but I'm having some problems keeping the input data.
I'm using the SERIN command to get data from the keypad through a 4x20 LCD display.
I'd like to write a 4 digit pin code to the eeprom at the beginning of the program and name it pin_code or something (eks 1234)
Then I'd like to store the 4 digit input from the keypad as, let's say, pin_entered.
IF pin_code = pin_entered THEN granted
You get the point?
How can this be done??
Thanks..
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2005-04-14 10:06
    WhipeOut -
    Play around with this rudimentary and incomplete program.
    Saved_Pin var Byte(4)
    Saved_Pin(0) = 1 'First digit of valid pin
    Saved_Pin(1) = 2 'Second digit of valid pin
    Saved_Pin(2) = 3 'Third digit of valid pin
    Saved_Pin(3) = 4 'Fourth digit of valid pin
    Pin_Number var byte(4)
    SERIN PIN_NUMBER\4
    For n =·0 to 3
    IF Saved_Pin(n) = Pin_Number(n) then Next_Pin
    Go to Bad_Pin
    Next_Pin: Next
    Pin_Okay:
    Bad_Pin:
    END
    Bruce Bates
    Post Edited (Bruce Bates) : 4/15/2005 5:23:27 AM GMT
  • WhipeOutWhipeOut Posts: 13
    edited 2005-04-14 10:49
    Thanks... I'll try this one... [noparse];)[/noparse]
    edited 2005-04-14 21:31
    Wouldn't it be easy to breake this PIN if you'd have to match the first digit to continue??
    edited 2005-04-15 05:21
    WhipeOut -
    As I said "play around with this rudimentary and incomplete program". If you want to make it more secure you can change it any way you choose to. The person entering the pin must enter all 4 digits, so they have no idea when or where the comparison failed.
    I did make some changes to the original routine, however, to correct an array positioning error.
    Bruce
  • Beau SchwabeBeau Schwabe Posts: 6,573
    edited 2005-04-15 05:40
    Just to offer another approach I have used with writing my own screen savers...
    If you had a "fixed" buffer of a specific width i.e 4 digits, simply roll out the last digit and roll in the new digit.
    When the equivalent of "ENTER" had been pressed compare what is in the buffer.
    Initialize:
    MainLoop:
    {Detect Key Press here and Jump to KeyPressed}
    goto MainLoop
    KeyPressed:
    {If NewKey = "ENTER" then Jump to CodeTest}
    Saved_Pin(4) = Saved_Pin(3)
    Saved_Pin(3) = Saved_Pin(2)
    Saved_Pin(2) = Saved_Pin(1)
    Saved_Pin(1) = NewKey
    KeyRelease:
    {Detect Key Release here and Jump to MainLoop}
    goto KeyRelease
    CodeTest:
    {Compare Buffer to valid codes and do something here from the comparison}
    goto MainLoop
    Beau Schwabe - Mask Designer III
    National Semiconductor Corporation
    Latest Company News
    (Communication Interface Division)
    500 Pinnacle Court, Suite 525
    Mail Stop GA1
    Norcross,GA 30071
    Thanks guys...
    I'll check the functionality when it's time.
