Power Jack Issue
Hello,
I put together a circuit on a PCB, and one of my elements is a 3 pin power jack.· When I plug in my supply, the power LED does not turn on, but, through trial and error, it will turn on when I put my finger on the metal surface of the back of the jack (I think it's part of the neg terminal but it could be GND).· My circuit is valid and I'm using the appropriate supply, and I've been tinkering with the jack's soldering but I can't fix it.· It would make sense if the part I'm touching is the GND term, and it is only properly grounded to my body, but it's more likely this terminal is the negative one.· So anyone got a clue whats going on?
Chris Isaacson
