Testing relays??
--Hiya; I'm using the Opto 22 relay board and BS2. I've written a simple program that should be turning a relay on and off at one second intervals. To test that the relay is working I'm using·my voltmeter's beeping·continuity tester, but to date I've not made a "contact". Any ideas what might be going on? I notice that the little LED on the relay I'm testing is blinking in time with the program, but there doesn't seem to be anything else going on..
·· If you're using SSRs, you won't get continuity that way.·· These devices are specifically design to switch a load (Usually AC) using solid state components.· In the case of the AC version, by switching during the AC signal's zero-crossing point.· You will simply have to switch the appropriate load to test them.
csavage@parallax.com
···· --Ya know, it would be neat if Parallax offered a relay with a transparent case, so one could observe the internal workings in action..
························ Hacking the Trailing Edge!
················http://www.nmpproducts.com/intro.htm
················---Decks a-wash in a sea of words---
·· If the DC Relay is an Opto 22 SSR, then even a clear case won't help you as these are not mechanical relays.· Inside is solid state circuitry controlled by an optically coupled interface, consisting of an LED (sealed) and a photo-transistor type interface, along with power control circuitry, although this varies since no manufacturer wants you to know exactly how theirs works.· But the block diagram is the equivalent.
·· Basically if you can hear the relay click when it activates, then it's probably mechanical, and you should be able to test for continuity.· If not, try measuring resistance instead, and you should see it drop (Even on the SSR).
···· --Also finally got voltmeter readings when I reversed the probes, so I can verify that the relays are, indeed, working.
·· I'm glad you finally got that figured out, but if you could explain exactly what you're trying to do, what you want to connect, and what loads you're trying to drive, maybe a better solution could be suggested.
··· --I've got it all working on the testbench; the next goal will be to get it sorted out on the vehicle in such a way that it's weatherproof and the cable routing is not going to get whacked and broken. Never the tidy person, me, I see many zipties in my future!
