digi pot
i am trying to digitally controll the brightness of 24 leds as one unit·in a smooth motion(up and down). is it possible to do this with a digital potentiometer like the ad5220 if so what is the best setup.·
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
As Bean mentioned, the PWM command will work well.
Do you know what the forward voltage is for the LEDs you have chosen?
The forward voltage information is needed to know what series value resistor is needed in·with each group of 4 LEDs.
The drawing attached has a group of 20 LEDs controlled with one 2n2222 transistor. You will simply add one more group of 4.
red:
Forward Voltage (V) : 1.8 ~ 2.2·
Max Continuous Forward Current : 30mA
Max Peak Forward Current : 75mA
yellow:
white:
foward voltage min=2.8, typ=3.5, max=4.0
foward current max=30ma
blue:
foward voltage= min=2.8, typ=3.5, max=4.0
