Need some help confirmation please ...
I posted a few days ago regarding powering a very large servo through the STAMP and got very good advice (thanks Jonb and allanlane5). I was able to plug the BOE bot continuous rotation servo into a separate power supply and still send signals to the servo. My question is whether this plan will work "safely". Here it is. I have a servo that requires 6V and I have a 6 cell, 6V NiMH battery(1100mAh). If I use the same exact setup that I tested the smaller servo on (which was only on a 3V supply) will I be in any danger of damaging the microcontroller? The power supply will go to the servo and the grounds will be common. If anyone sees any potential red flags please let me know. Sorry if this sounds like a dumb question and thanks for any input.
Your new setup (Servo Power, BS2 Power, common ground) should work fine.
