Running an SX on 3.3v for MMC/SD integration...
Hi guys - quick noob question for you,
I'm researching how to integrate an MMC / SD or even CompactFlash card with my SX28. From everything I've read about MMC/SD (from links in these forums) I'll have to power both the storage card itself at 3.3v and also communicate with it at 3.3v. I also seem to remember reading that if I drop the SX voltage to 3.3v that the SX-Key won't work with the SX chip (i.e. programming and debugging would be impossible).
I realize similar questions have been asked in the past, but is there an easy way to work with the SX28 / SX-Key at a lower voltage? Alternatively are there any MMC / SD / CF storage devices out there that can interoperate with the SX at it's "native" 5v? I'd really like to get "stuck-in" to the programming side of integrating an MMC but am not sure how best to get going on the hardware side.
Thanks for any tips or pointers!
D.
D.
csavage@parallax.com
http://www.sxlist.com/techref/parallax/sxkey.htm
William K Borsum of Dascor says:
There is a DC-DC on the board but they couldn't/wouldn't tell me specifically what it was for.
The outputs from the SX-Key (OSC1, 2) must NOT be clamped to anything. Apparently there is a higher voltage required on these pins to tell the target chip that it is in SX-Key/debug/program mode.
The higher voltage on OSC1 and OSC2 will NOT appear on any other pins of the target chip.
The five volt supply on the SX-key can be different from the target chip--i.e. the SXkey can run from a five volt supply (single 7805, caps and wall wart= SX-Key-Ring) while the target system runs from its own supply. Only common pins are GND, OSC1, OSC2. The power rails are NOT connected if a different voltage.
James Newton, Host of SXList.com
james@sxlist.com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
You're right - the Sx could work from 3.3V, but then you couldn't program it with the SX-Key. What I did was to make a separate 3.3V supply with zener diodes to power the memory card.
My Sx drove 3 discrete transistors to drive the card inputs, where the transistor collector resistor went to the 3.3V supply, the collector went to the card, and the Sx drove the base resistor. I sent the card output directly to a 74HCT14 Schmidt buffer; the card output was sufficient to trigger the Schmidt which fed the Sx.
So my hardware was just about as cheap and simple as possible but still worked.
David
Chris - you mention the SX-Key-Ring used to be available - does that mean it's no longer available to order? Do you still have any information on it? I think from what James is saying the Key-Ring is basically just 7805 regulator and a couple of capacitors?
DavidB - sounds like your approach might be simpler - from what I understand (and I'm very newbie here!) if I power the MMC seperately I should be fine (using the transistors you mention for input and a Schmidt buffer for the MMC output) - how would that kind of approach work in "production"? Once I've developed my application, would I simply drop the entire circuit down to 3.3v (and remove the transistors and Schmidt buffer) or would I require seperate batteries for the MMC's 3.3v power versus the SX?
Thanks again guys,
D.
A couple of the other posts suggest you could run the SX at a separate voltage from the SX-Key. Maybe you could drive the cards directly from the Sx, with both running from 3.3V, and power the SX-Key to 5V separately. I've never tried that, but that might be a simpler way to get your project started.
D.
From what I can tell in that link, all I need is a 3.3v regulator to power the MMC and a couple of resistors for SX -> MMC. This is a really newb question, but can I "feed' the 3.3v regulator and the SX from the same 5v source on the SX board (or do I need a seperate wall-wart?)?
Thanks for everyone's kind assistance!!
D.
