bs2 3 large dc motors, need reversible controller with pwm
is there a reversible speed··controller for dc motors, brused and brushless, that will handle a 40 amp motor at 12 volts?· It would be nice if it could be controlled form the stamp 2·and the controller could·generate it's own pwm based on some sort of output from the stamp.· Simultaneous use of the motors is required.·
Then you need a PWM controller to drive the H-Bridge. This provides Pulse-Width-Modulation of your 12-volts (basically on for a little, off for a little) which gives you speed control.
Now you need to size the H-Bridge to handle your voltage and current. There's lots of possibilities, google H-Bridge. And you need a PWM controller which you can talk to with the BS2 -- serial or parallel.
Post Edited (allanlane5) : 4/14/2005 5:03:20 PM GMT
I have not used it but just saw it yesterday while snooping around. Looks pretty versatile if not powerful enough for your needs.
http://www.robot-electronics.co.uk/shop/Motor_Controllers2008.htm
HTH, Floyd
Post Edited (Paul Baker) : 4/14/2005 5:03:19 PM GMT
