Outputing a variable to LCD
We want to combine the code below·and we also want to include a calculated variable after top speed.· Any suggestions?
' {$STAMP BS2}
[noparse][[/noparse] Constants ]
' Ports used
················ RS CON 4 ' Register Select (1 = char)
················ E CON 5· ' LCD Enable pin (1 = enabled)
' LCD control characters
················ ClrLCD CON $01 ' clear the LCD
················ CrsrHm CON $02 ' move cursor to home position
················ CrsrLf CON $10 ' move cursor left
················ CrsrRt CON $14 ' move cursor right
················ DispLf CON $18 ' shift displayed chars left
················ DispRt CON $1C ' shift displayed chars right
················ DDRam CON $80· ' Display Data RAM control
[noparse][[/noparse] Variables ]
················ char VAR Byte· ' character sent to LCD
················ index VAR Byte ' loop counter
[noparse][[/noparse] EEPROM Data ]
················ Msg DATA "Top Speed: "·· ' preload message
[noparse][[/noparse] Initialization ]
Init:··········· DIRL = %00111111·· ' set pins 0-5 as outputs
················ OUTS = $0000······ ' clear the pins
' Initialize the LCD (Hitachi HD44780 controller)
LCDinit:········ PAUSE 500 ' Wait for LCD init
················ ' STANDARD HITACHI 44780 4-BIT INIT
················ char=%00000011 ' Set 8-bit mode (1)
················ GOSUB LCDcmd
················ char=%00000011 ' Set 8-bit mode (2)
················ char=%00000011 ' Set 8-bit mode (3)
················ char=%00000010 ' Set 4-bit mode
················ char=%00101111 ' Set duty cycle 11xx = 5x11 matrix
················ GOSUB LCDcmd·· ' 10xx = 5x8 matric
················ char=%00000000 ' Display control mode
················ char=%00001000 ' Set display OFF, cursor OFF, blink OFF
················ char=%00001111 ' Set display ON, cursor ON, blink ON
················ GOSUB LCDcmd·· ' 11CB -> C=1 cursor on, B=1 blink on
················ char=%00000000 ' Entry control mode
················ char=%00000110 ' Set cursor right, no display shift
················ GOSUB LCDcmd·· ' 01IS -> I=1 cursor right, S=1 shift display
················ char = ClrLCD· ' Clear LCD
[noparse][[/noparse] Main Code ]
Start:
················ FOR index = 0 TO 39
·················· READ Msg + index, char ' get character from memory
·················· GOSUB LCDwr··········· ' write it to the LCD
················ NEXT
················ PAUSE 4000·············· ' wait 2 seconds
················ 'char = ClrLCD··········· ' clear the LCD
················ GOTO LCDinit·············· ' do it all over
[noparse][[/noparse] Subroutines ]
' Send command to the LCD
LCDcmd:········· LOW RS ' enter command mode
' Write ASCII char to LCD
LCDwr:
················ OUTA = char.HIGHNIB ' output high nibble
················ PULSOUT E, 1······· ' strobe the Enable line
················ OUTA = char.LOWNIB· ' output low nibble
················ HIGH RS············ ' return to character mode
················ RETURN
' {$STAMP BS2}
' Ports used
Start:
LCDwr:
Print_Value:
· FOR idx = 4 TO 0···················· ' print five digits
··· char = (theValue DIG idx) + "0"··· ' get digit, convert to ASCII
··· GOSUB LCDwr······················· ' print on LCD
· NEXT
· RETURN
Change the starting value of the FOR-NEXT loop to control how many digits get printed.· If, for example, you only needed three digits on the display, the starting value would be 2.
Jon Williams
Dallas, TX· USA
