BS2P40 Detection
My new BS2p40 won't be detected by computer running the BSEditor 2.1 beta 1.· I even had my electronics teacher check my wiring of the cable between my computer and the stamp.· The loopback and echo both·say yes but there is no device type or version.· I assume some of it must be working to get both the loopback and echo to respond.
Kirk W. Fraser
Kirk W. Fraser
Jon Williams
Dallas, TX· USA
··········· If you have access to a voltmeter what do you get on the following pins of the stamp with reference to ground (Pin·39 -VSS)?
Pin·40 -VIN
Pin·38 - RST
Pin·37 – VDD
Pin 1 – SOUT
Pin 2 – SIN
Pin 3 – ATN
Stephen Swanson
Technical Support
sswanson@parallax.com
I believe the Stamp is powered properly with 12vdc.
The reset pin has nothing external connected to it.
Stephen,
Pin 40 -VIN 12.24
Pin 38 - RST 9.00
Pin 37 – VDD 9.00
Pin 1 – SOUT 9.93
Pin 2 – SIN 13.29
Pin 3 – ATN 7.05
Kirk
·Ok, this is the·problem you seem to have 9vdc on VDD which could damage the stamp. You will want to see what is providing this 9vdc to the VDD or RST. This will need to be removed before inserting the stamp.
Stephen Swanson
Technical Support
The problem was my ground was open -- my proto board needs a jumper half-way down the ground line.
Now the Stamp identifies itself in my computer correctly.
Thanks for your patience and assistance.
Kirk
