using robocode to test out logic and ranging
Don't know if this is the appropriate forum for this, but figured since this Javalin uses java that you fellow jav users would like this.
I thought this would be useful for writing and seeing what the bot would do with simple commands. Mind you, that you are very limited with the javalin proc and may not be able to do everything, you still could at least write the code in the robocode editor knowing your limitations and see what it would look like in a virtual world....plus a great way to learn a language [noparse]:)[/noparse]
Anyone else use this??? or have anything better that they could recommend?
Mark
Mark
