SX/B compiler crash
Hi folks,
I have managed (if was hard work ;-) to write some code that crashes the compiler.
I enclose the code (which is very unfinished - no criticisms please), and some dump info of the 'crash'.
Anyone got any ideas?
Something to get me a bit further?· Presumably someone supports the compiler itself and may be able to work out what my code is doing wrong to cause the problem.
DUMP info start here....
(replace this text with your code) ' ========================================================================= ' ' Started... 01-Mar-2005 ' Updated... ' ' ========================================================================= ' ------------------------------------------------------------------------- ' Program Description ' ------------------------------------------------------------------------- ' ------------------------------------------------------------------------- ' Device Settings ' ------------------------------------------------------------------------- DEVICE SX28, OSCHS3, TURBO, STACKX, OPTIONX IRC_CAL IRC_FAST FREQ 25_000_000 ' ------------------------------------------------------------------------- ' IO Pins ' ------------------------------------------------------------------------- ' ------------------------------------------------------------------------- ' Constants ' ------------------------------------------------------------------------- 'int_period CON 166 ; This sets the I2C bus frequency. (50MHz chip and 100kHz bus) 'int_period CON 108 ; This sets the I2C bus frequency. (50MHz chip and 154kHz bus) int_period CON 83 ; This sets the I2C bus frequency. (25MHz chip and 100kHz bus) '; Also used as seed for UART baud rate. '; int_period = clk_speed/(3 x bus_speed) '; eg. for 100kHz operation : int_period = 50Mhz/(3 x 100kHz) = 166 strt_delay CON 4 'How long (in clock cycles) to wait for start bit (or something) ';********************************************************************************* '; UART Constants '; The following three values determine the UART baud rate. '; The value of baud_rate and int_period affect the baud rate as follows: '; Baud rate = 50MHz/(baud_rate * int_period * RTCC_prescaler) '; Baud rate = 25MHz/(12? * 83 * ??? ) '; 12? * ??? = (19200 * 83 )/25MHz '; 12? * ??? = (19200 * 166 )/50MHz '; '; Note: *int_period must <256 and longer than the length of the slowest possible '; interrupt sequence in instruction cycles. Changing the value of int_period will '; affect the rest of the virtual peripherals due to timing issues. The start delay '; value must be set equal to (baud_rate)*1.5 + 1 ';********************************************************************************* '; *** 2400 baud (for slower baud rates, increase the RTCC prescaler) baud_rate_24 CON 96 ';for 2400 baud rate generation start_del_24 CON baud_rate_24+(baud_rate_24/2)+1 '; *** 9600 baud baud_rate_96 CON 24 ';for 9600 baud rate generation start_delay_96 CON baud_rate_96+(baud_rate_96/2)+1 '; *** 19200 baud baud_rate_192 CON 12 ';for 19200 baud rate generation start_delay_192 CON baud_rate_192+(baud_rate_192/2)+1 '; *** 38400 baud baud_rate_384 CON 6 ';for 38400 baud rate generation start_delay_384 CON baud_rate_384+(baud_rate_384/2)+1 '; *** 57600 baud baud_rate_576 CON 4 ';for 57600 baud rate generation start_delay_576 CON baud_rate_576+(baud_rate_576/2)+1 ';***************************************************************************************** '; Port Assignment '; RX_io : sets direction registers '; RX_init : sets the ports initial value ';***************************************************************************************** RA_init CON %11111111 ';SX18/20/28/48/52 port A latch init RA_io CON %11111111 ';SX18/20/28/48/52 port A DDIR value RB_init CON %11111111 ';SX18/20/28/48/52 port B latch init RB_io CON %01110111 ';SX18/20/28/48/52 port B DDIR value RC_init CON %00011111 ';SX18/20/28/48/52 port C latch init RC_io CON %00011100 ';SX18/20/28/48/52 port C DDIR value ';***************************************************************************************** '; Pin Definitions ';***************************************************************************************** i2c_port VAR rb uart_port VAR ra led_port VAR rc scl CON 1 sda CON 0 scl_pin VAR i2c_port.scl '; I2C clock sda_pin VAR i2c_port.sda '; I2C data I/O rx_pin1 VAR uart_port.2 ;UART1 receive input tx_pin1 VAR uart_port.3 ;UART1 transmit output rx_pin2 VAR uart_port.6 ;UART2 receive input tx_pin2 VAR uart_port.7 ;UART2 transmit output ';Address of the slave device MWSlave CON $88 '; Optional LEDs for debugging purposes... green_led VAR led_port.7 red_led2 VAR led_port.6 red_led1 VAR led_port.5 '';***************************************************************************************** '; Data Memory address definitions '; These definitions ensure the proper address is used for banks 0 - 7 for 2K SX devices '; (SX18/20/28) and 4K SX devices (SX48/52). ';***************************************************************************************** global_org CON $08 bank0_org CON $10 bank1_org CON $30 bank2_org CON $50 bank3_org CON $70 bank4_org CON $90 bank5_org CON $B0 bank6_org CON $D0 bank7_org CON $F0 ' ------------------------------------------------------------------------- ' Variables ' ------------------------------------------------------------------------- main_temp VAR Byte isr_temp VAR Byte ; Temporary variable used by the ISR. flags VAR Byte uart_rx_flag VAR flags.0 ; flag set when data received by UART active_uart_isr_flag VAR flags.1 ; uart flag used in ISR to switch between UARTs main_temp2 VAR Byte main_temp3 VAR Byte main_temp4 VAR Byte MyCount VAR Byte ISrSlice VAR Byte I2CWorkSet VAR Byte(8) I2C_State VAR I2CWorkSet(0) I2C_Sub_State VAR I2CWorkSet(1) I2C_Strt_Ctr VAR I2CWorkSet(2) I2C_Index VAR I2CWorkSet(3) I2C_Byte VAR I2CWorkSet(4) I2C_Bit_Count VAR I2CWorkSet(5) I2C_Num_bytes VAR I2CWorkSet(6) I2C_Flags VAR I2CWorkSet(7) I2C_nack VAR I2C_flags.0 '; This bit is set if the I2C master has received a NACK from the slave I2C_rx_flag VAR I2C_flags.1 '; Indicates that the number of bytes requested have been received I2C_lost_arb VAR I2C_flags.2 '; indicates that this master has lost arbitration I2C_doing_write VAR I2C_flags.4 '; Used to remember whether doing a read or write when recovering from loss of arbitration I2C_in_control VAR I2C_flags.5 '; Indicates that this master thinks it is in control of the I2C bus I2C_Busy VAR I2C_flags.6 '; Indicates that this master thinks it is in control of the I2C bus I2C_buffer VAR Byte(6) '$ ; The buffer uses the last 7 registers of this bank (pre-increments, so put I2CM buffer here.) I2C_address VAR I2C_Buffer(0) '; The address to read/write to. I2C_data_0 VAR I2C_Buffer(1) '; Data buffer I2C_data_1 VAR I2C_Buffer(2) '; Data buffer I2C_data_2 VAR I2C_Buffer(3) '; Data buffer I2C_data_3 VAR I2C_Buffer(4) '; Data buffer I2C_data_4 VAR I2C_Buffer(5) '; Data buffer ' I2C_data_5 VAR I2C_Buffer(6) '; Data buffer I2CaVars VAR Byte(8) 'Reserves the space for the moment I2Ca_State VAR I2CaVars(0) I2Ca_Sub_State VAR I2CaVars(1) I2Ca_Strt_Ctr VAR I2CaVars(2) I2Ca_Index VAR I2CaVars(3) I2Ca_Byte VAR I2CaVars(4) I2Ca_Bit_Count VAR I2CaVars(5) I2Ca_Num_bytes VAR I2CaVars(6) I2Ca_Flags VAR I2CaVars(7) I2Ca_nack VAR I2Ca_flags.0 '; This bit is set if the I2C master has received a NACK from the slave I2Ca_rx_flag VAR I2Ca_flags.1 '; Indicates that the number of bytes requested have been received I2Ca_lost_arb VAR I2Ca_flags.2 '; indicates that this master has lost arbitration I2Ca_doing_write VAR I2Ca_flags.4 '; Used to remember whether doing a read or write when recovering from loss of arbitration I2Ca_in_control VAR I2Ca_flags.5 '; Indicates that this master thinks it is in control of the I2C bus I2Ca_Busy VAR I2Ca_flags.6 '; Indicates that this master thinks it is in control of the I2C bus I2Ca_Buffer VAR Byte(6) '$ ; The buffer uses the last 7 registers of this bank (pre-increments, so put I2CM buffer here.) I2Ca_address VAR I2Ca_Buffer(0) '; The address to read/write to. I2Ca_data_0 VAR I2Ca_Buffer(1) '; Data buffer I2Ca_data_1 VAR I2Ca_Buffer(2) '; Data buffer I2Ca_data_2 VAR I2Ca_Buffer(3) '; Data buffer I2Ca_data_3 VAR I2Ca_Buffer(4) '; Data buffer I2Ca_data_4 VAR I2Ca_Buffer(5) '; Data buffer ' I2Ca_data_5 VAR I2Ca_Buffer(6) '; Data buffer I2CbVars VAR Byte(8) 'Reserves the space for the moment I2Cb_State VAR I2CbVars(0) I2Cb_Sub_State VAR I2CbVars(1) I2Cb_Strt_Ctr VAR I2CbVars(2) I2Cb_Index VAR I2CbVars(3) I2Cb_Byte VAR I2CbVars(4) I2Cb_Bit_Count VAR I2CbVars(5) I2Cb_Num_bytes VAR I2CbVars(6) I2Cb_Flags VAR I2CWorkSet(7) I2Cb_nack VAR I2Cb_flags.0 '; This bit is set if the I2C master has received a NACK from the slave I2Cb_rx_flag VAR I2Cb_flags.1 '; Indicates that the number of bytes requested have been received I2Cb_lost_arb VAR I2Cb_flags.2 '; indicates that this master has lost arbitration I2Cb_doing_write VAR I2Cb_flags.4 '; Used to remember whether doing a read or write when recovering from loss of arbitration I2Cb_in_control VAR I2Cb_flags.5 '; Indicates that this master thinks it is in control of the I2C bus I2Cb_Busy VAR I2Cb_flags.6 '; Indicates that this master thinks it is in control of the I2C bus I2Cb_buffer VAR Byte(6) '$ ; The buffer uses the last 7 registers of this bank (pre-increments, so put I2CM buffer here.) I2Cb_address VAR I2Cb_Buffer(0) '; The address to read/write to. I2Cb_data_0 VAR I2Cb_Buffer(1) '; Data buffer I2Cb_data_1 VAR I2Cb_Buffer(2) '; Data buffer I2Cb_data_2 VAR I2Cb_Buffer(3) '; Data buffer I2Cb_data_3 VAR I2Cb_Buffer(4) '; Data buffer I2Cb_data_4 VAR I2Cb_Buffer(5) '; Data buffer ' I2Cb_data_5 VAR I2Cb_Buffer(6) '; Data buffer ';***************************************************************************************** '; Global Register definitions '; NOTE: Global data memory starts at $0A on SX48/52 and $08 on SX18/20/28. ';***************************************************************************************** '??? org global_org ' ------------------------------------------------------------------------- INTERRUPT ' ------------------------------------------------------------------------- SWFlags VAR byte WhichI2C VAR SWFlags.0 PBuf VAR Byte(2) Param_Ptr VAR byte ISR_Start: ' ISR code here 'ALWAYS perform ISR handling for I2C busses - one on each cycle 'Perform I2C handling - 1 and 2 if WhichI2C = 0 goto ISRI2Cb ISRI2Ca: 'Perform I2Ca handling GOSUB I2C_ISR, @I2CaVars(0) GOTO ToggI2C ISRI2Cb: 'Perform I2Cb handling GOSUB I2C_ISR, @I2CbVars(0) 'or a long list of them ToggI2C: 'Toggle between I2C busses for the next ISR cycle. WhichI2C=NOT WhichI2C 'Start of ISR for I2C I2C_ISR: 'Get the variables (Parameters???? related to the calling instance Param_Ptr = __PARAM1 GET Param_Ptr, I2C_State, I2C_sub_state, I2C_Strt_Ctr, I2C_Index, I2C_Byte, I2C_Bit_Count, I2C_Num_bytes 'Now operate the State machine for I2C bus BRANCH I2C_State, I2C_idle, I2C_Start, I2C_start_write, I2C_write, I2C_write, I2C_get_ack, I2C_write_repeat, I2C_stop, I2C_start, I2C_start_read, I2C_write, I2C_get_ack, I2C_read_data, I2C_read, I2C_store_byte, I2C_send_ack, I2C_stop 'State routines ' ;*********************************************************************************' ' ; State: I2CM_idle ' ; This is the state that the I2C Master is usually in when it is not in use. ' ; It just ensures that the I2C_port_buf SCL and SDA are both set high ' ;********************************************************************************* I2C_idle: 'Main State - idle \ setb I2C_port_buf.sda \ setb I2C_port_buf.scl goto State_Done ' ;********************************************************************************* ' ; State: I2CM_start ' ; When any mainline program wants to use the I2C master it puts the master into ' ; start mode. This mode creates a start condition on the I2C bus. A start ' ; condition is created when SDA goes from high to low while SCL stays high. ' ;********************************************************************************* I2C_start: 'Main State for starting BRANCH I2C_sub_state, SubState1, SubState2, SubState3, SubState4, Substate5 SubState1: \ setb I2C_port_buf.scl ;1 \ setb I2C_in_control ;1 \ setb I2C_port_buf.sda ;1 I2C_strt_ctr = strt_delay 'Set start delay using a constant ;2 goto IncSubState SubState2: '; --- WAITING FOR STOP/START OR IDLE SCL --- \ sb scl_pin ';1 \ clr I2C_sub_state ';1 DEC I2C_strt_ctr ';1/2 IF Z = 0 GOTO State_Done ' ;3 goto IncSubState ' ;3 = 6/8 + 7 = 13/15 SubState3: 'Finished Clock synchronisation (I think) \ clrb I2C_port_buf.sda ';1 goto IncSubState ' ;3 = 5 + 7 = 12 SubState4: \ clrb I2C_port_buf.scl ';1 goto IncSubState ' ;3 = 6/8 + 7 = 13/15 SubState5: \ setb I2C_port_buf.sda ;1 \ clr I2C_sub_state ;1 'goto IncSubState ;3 = 6/8 + 7 = 13/15 IncSubState: INC I2C_sub_state Goto State_Done ' ;********************************************************************************* ' ; State: I2CM_start_write ' ; This state performs some pre-processing which allows the I2CM_write state to ' ; do its work. It sets up the bit count, gets the next piece of data from the ' ; buffer and prepares to send it. ' ;********************************************************************************* I2C_start_write: 'Main State start a write cycle INC I2C_index GET I2C_Index, I2C_Byte 'Get the byte pointed at by the index ptr. 'What is full address - ASM code ??? I2C_Bit_Count = 8 '8 bits to send. INC I2C_State 'go to the next state GOTO State_Done ' inc I2CM_index ';1' ' mov w,I2CM_index ';1 ' add fsr,w ';1 ' mov w,indf ;1 ' mov I2CM_byte,w ;1 ' mov w,#8 ;1 ' mov I2CM_bit_count,w ;1 ' inc I2CM_state ;1 ' retp ;3 = 12 + 7 = 19 ' ;*********************************************************************************' ' ; State: I2CM_write ' ; This state writes the data in I2CM_byte to the I2C bus ' ;********************************************************************************* I2C_write: 'Main State - do writing BRANCH I2C_sub_state, wstate1, wstate2, wstate3 wstate1: \ setb I2C_in_control \ setb I2C_port_buf.sda ;1 \ rl I2C_byte ;1 \ sc ;1 \ clrb I2C_port_buf.sda ;1 INC I2C_sub_state ';1 goto State_Done 'retp ;3 = 15 + 7 = 22 wstate2: \ setb I2C_port_buf.scl ;1 INC I2C_sub_state ';1 goto State_Done 'retp ;3 = 12 + 7 = 19 wstate3: \ clrb I2C_port_buf.scl ;1 DEC I2C_bit_count ';1 'snz ;1 IF I2C_bit_count = 0 GOTO Wdone 'jmp :done ;3 I2C_sub_state = 0 'clr I2CM_sub_state ;1 goto State_Done 'retp ;3 = 14 + 7 = 21 Wdone: I2C_sub_state = 0 ';1 INC I2C_state ';1 \ clrb I2C_in_control goto State_Done ' ;********************************************************************************* ' ; State: I2CM_get_ack ' ; This state gets an ACK from the slave device. If no ACK is received, the I2C ' ; Master state machine puts a stop condition on the bus and the I2CM_flags ' ; register is loaded to indicate that a NACK has occurred. ' ;********************************************************************************* I2C_get_ack: BRANCH I2C_Sub_State, GetAckState1, GetAckState2, GetAckState3, GetAckState4 ' mov w,I2CM_sub_state ;1' ' add pc,w ;3 ' jmp :state1 ;3 ' jmp :state2 ;3 ' jmp :state3 ;3 ' jmp :state4 ;3 ':state1 GetAckState1: \ setb I2C_port_buf.sda ';1 INC I2C_sub_state ';1 GOTO State_Done 'retp ;3 = 13 + 7 = 20 ':state2 GetAckState2: \ setb I2C_port_buf.scl ';1 GetAckStateDone: INC I2C_sub_state ';1 GOTO State_Done 'retp ;3 = 12 + 7 = 19 ':state3 GetAckState3: if sda_pin = 0 GOTO State3done ' sb sda_pin ;1 ' INC I2C_sub_state ';1 ' sb sda_pin ;1 LET I2C_State = 20 'I2C_Stop_Loc - I2C_Idle_Loc 'Set the value of the STOP state. ' mov w,#(I2CM_stop_loc-I2CM_idle_loc);1 ' mov I2CM_state,w ;1 \ clr I2C_sub_state ;1 ;send a stop and indicate that this didn't work. \ setb I2C_NACK ;1 ;set I2CM_NACK to show that this did not go through. GOTO State_Done 'retp ;3 = 17 + 7 = 24 ':state4 GetAckState4: \ clrb I2C_port_buf.scl ;1 \ clr I2C_sub_state ;1 INC I2C_state ';1 ;move on to next state GOTO State_Done 'retp ;3 = 13 + 7 = 20 ' ;********************************************************************************* ' ; State: I2CM_write_repeat ' ; This state determines, after one byte of data is sent, whether or not ' ; there is another byte to be sent. If so, this state goes back to ' ; I2CM_start_write and sends the next byte. ' ;********************************************************************************* I2C_write_repeat: if I2C_num_bytes = I2C_index GOTO I2C_Write_Done ' mov w,I2CM_num_bytes ;1 ;test the read index to see if it is = to write index.' ' xor w,I2CM_index ;1 ;if it is, then we have finished writing the buffer via. I2C. ' snz ;1 ' jmp :I2CM_write_done ;3 I2C_State = I2C_State - 3 'Step the state back to Write data ' dec I2CM_state ;1 ;back to get_ack ' dec I2CM_state ;1 ;back to write ' dec I2CM_state ;1 ;back to write_data GOTO State_Done 'retp ;3 = 16 + 7 =23 I2C_write_done: INC I2C_state ';1 ;move on to next state (stop) GOTO State_Done 'retp ;3 = 17 + 7 = 24;and start the stop bit ' ;********************************************************************************* ' ; State: I2CM_stop ' ; This state puts a stop condition on the I2C bus and resets the state machine back ' ; to its idle state. A stop condition is when SDA goes from low to high while SCL ' ; is high. ' ;********************************************************************************* I2C_stop: BRANCH I2C_Sub_State, StopSubState1, StopSubState2, StopSubState3 ' mov w,I2CM_sub_state ;1 ' add pc,w ;3 ' jmp :state1 ;3 ' jmp :state2 ;3 ' jmp :state3 ;3 StopSubState1: \ setb I2C_in_control \ clrb I2C_port_buf.sda ;1 \ inc I2C_sub_state ;1 GOTO State_Done 'retp ;3 = 13 + 7 = 20 StopSubState2: \ setb I2C_port_buf.scl ;1 \ inc I2C_sub_state ;1 GOTO State_Done 'retp ;3 = 13 + 7 = 20 StopSubState2: \ setb I2C_port_buf.sda ;1 \ clr I2C_sub_state ;1 ;put the state machine in Idle \ clr I2C_state ;1 \ clr I2C_num_bytes ;1 I2C_Index = $FF ' mov w,#$ff ;1 ' mov I2CM_index,w ;1 \ clrb I2C_in_control GOTO State_Done 'retp ;3 = 16 + 7 = 23 ' State Done is where we exit the routine. ' it does not mean that we have finished with a state - only that this cycle of it has completed State_Done: 'Pass the parameters for this instance back to the caller locations PUT Param_Ptr, I2C_State, I2C_sub_state, I2C_Strt_Ctr, I2C_Index, I2C_Byte, I2C_Bit_Count, I2C_Num_bytes RETURN 'End of the I"C state machine '***************************** 'End of I2C part of ISR handling ' Move on to servicing the other routines. '***************************** 'How do we get here???????????????????????????????? 'Decrement the ISR counter DEC ISRslice PickISR: BRANCH ISRslice, Slice0, Slice1, Slice2, Slice3, Slice4, Slice5, Slice6, Slice7, Slice8, Slice9 Slice0: ISRslice = 2 'There are 'n' interrupt slices 'Zero is a non-runner - go to num '5' goto PickISR Slice1: 'Count until ok to do some RS232a GOTO EndSlice Slice2: 'Count until ok to do some RS232b GOTO EndSlice Slice3: ISRslice = 5 'There are 'n' interrupt slices GOTO EndSlice Slice4: ISRslice = 5 'There are 'n' interrupt slices GOTO EndSlice Slice5: ISRslice = 5 'There are 'n' interrupt slices GOTO EndSlice Slice6: ISRslice=5 'There are 'n' interrupt slices GOTO EndSlice Slice7: ISRslice=5 'There are 'n' interrupt slices GOTO EndSlice Slice8: ISRslice=5 'There are 'n' interrupt slices GOTO EndSlice Slice9: ISRslice=5 'There are 'n' interrupt slices GOTO EndSlice EndSlice: ISR_Exit: RETURNINT ' {cycles} ' ========================================================================= PROGRAM Start ' ========================================================================= Pgm_ID: DATA "XLights", 0 ' ------------------------------------------------------------------------- ' Subroutines / Jump Table ' ------------------------------------------------------------------------- I2CaSend: 'Take "I2CaBytes" of data from "I2CaData" and send it to "I2CaDevice & I2CaAddr". 'First we wait for the bus to be not busy. IF I2Ca_Busy = 1 GOTO I2CaRcv 'NOT SURE IF THIS TEST IS RIGHT 'Once we have the bus, then load the ISR and trigger the fetch ' GOBSUB xxx RETURN I2CaRcv: 'Read "I2CaBytes" of data from "I2CaDevice & I2CaAddr" and put it into "I2CaData" 'First we wait for the bus to be not busy. IF I2Ca_Busy = 1 GOTO I2CaRcv 'Once we have the bus, then load the ISR and trigger the fetch RETURN I2CbSend: RETURN I2CbRcv: RETURN RS232aSend: RETURN RS232aRcv: RETURN RS232bSend: RETURN RS232bRcv: RETURN ' ------------------------------------------------------------------------- ' Program Code ' ------------------------------------------------------------------------- Start: ' initialization code here ISRSlice = 0 'Initialise interrupt counter 'Set up the data ports for all the RA = RA_init 'Set up Data ports TRIS_A = RA_io ' make LED ports outputs RB = RB_init 'Set up Data ports TRIS_B = RB_io ' make LED ports outputs RC = RC_init 'Set up Data ports TRIS_C = RC_io 'Start up the interrupt handler. Main: ' main code here pause 50 GOSUB RS232bSend GOSUB I2CaSend GOTO Main 'Loop - to detect boundary failures. ' ------------------------------------------------------------------------- ' Page 1 Code ' ------------------------------------------------------------------------- Page_1: ADDRESS $200 P1_Start: GOTO P1_Start ' error if Pg0 overruns Pg1 ' ------------------------------------------------------------------------- ' Page 2 Code ' ------------------------------------------------------------------------- Page_2: ADDRESS $400 P2_Start: GOTO P2_Start ' error if Pg1 overruns Pg2 ' ------------------------------------------------------------------------- ' Page 3 Code ' ------------------------------------------------------------------------- Page_3: ADDRESS $600 P3_Start: GOTO P3_Start ' error if Pg2 overruns Pg3 'END
XML Dump info capture by microsoft - best viewed in explorer I reckon. <?xml version="1.0" encoding="UTF-16"?> <DATABASE> <EXE NAME="SASM.dll" FILTER="GRABMI_FILTER_PRIVACY"> <MATCHING_FILE NAME="SASM.dll" SIZE="151552" CHECKSUM="0xF66A84BD" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="09/14/2004 21:21:10" UPTO_LINK_DATE="09/14/2004 21:21:10" /> <MATCHING_FILE NAME="SXKey.exe" SIZE="1897472" CHECKSUM="0x5D3C7B58" BIN_FILE_VERSION="2.2.7.183" BIN_PRODUCT_VERSION="2.2.7.183" PRODUCT_VERSION="2.02.07 BETA" FILE_DESCRIPTION="SX Tech Editor/Debugger" COMPANY_NAME="Parallax, Inc." PRODUCT_NAME="" FILE_VERSION="2.2.7.183" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="Copyright 1998-2003" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.2.7.183" UPTO_BIN_PRODUCT_VERSION="2.2.7.183" LINK_DATE="06/19/1992 22:22:17" UPTO_LINK_DATE="06/19/1992 22:22:17" VER_LANGUAGE="English (United States) [noparse][[/noparse]0x409]" /> <MATCHING_FILE NAME="Compilers\SXB\SXB.exe" SIZE="267776" CHECKSUM="0xBC6790A6" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="06/19/1992 22:22:17" UPTO_LINK_DATE="06/19/1992 22:22:17" /> </EXE> <EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY"> <MATCHING_FILE NAME="kernel32.dll" SIZE="983552" CHECKSUM="0x4CE79457" BIN_FILE_VERSION="5.1.2600.2180" BIN_PRODUCT_VERSION="5.1.2600.2180" PRODUCT_VERSION="5.1.2600.2180" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFF848" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.2180" UPTO_BIN_PRODUCT_VERSION="5.1.2600.2180" LINK_DATE="08/04/2004 07:56:36" UPTO_LINK_DATE="08/04/2004 07:56:36" VER_LANGUAGE="English (United States) [noparse][[/noparse]0x409]" /> </EXE> </DATABASE>
You need to trim the program down to the bare essential that still causes the error.
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
I'm also hoping that whoever publishes the compiler can find something to work on as well.
cheers
Martin
The SXKey software crashes for me with this code as well.
This is the same error I saw trying to compile the ASM macros from the SXList.
Please post the solution if you find one.
Jack
It seems the assembler doesn't like any line longer than 239 characters in the SRC file.
The BRANCH command on line 232 causes a line that is 269 characters long.
If you compile it, then open the generated SRC file and shorten that line to less than 240 characters it will assemble (there are problems with the program though).
For now if you shorten the label names in that BRANCH command, it should compile okay.
Bean.
www.sxvm.com
Post Edited (Bean) : 4/13/2005 2:25:49 PM GMT
I'll shrink the Branch line.
There are plenty of problems with the program I agree. I am in the phase of raw construction and have not yet understood what the compiler resolves for me in terms of the page handling, and what I have to declare explicitly in the program. I was going to take the approach of constructing most of the code (even if some was in stub form) and then learning by tweaking.
Do you know which parts of the docs might make this obvious to an SX novice/junior lilke me?
I have got my head around the 'page' stuff in assembler and the chip architecture. Should I simply regard the compiler as a pre-processor to the assembler? - i.e. it won;t solve the page pointer and 'first half of a page' "features" that the SX comes with? Or does the compiler contribute more than that?
Martin
The "soon to be released" version 1.2 of the compiler does handle the code page and 'first half of a page' issues automatically.
Keep and eye out for it's release.
Bean.
www.sxvm.com
