The Great Outdoors
OK, Picture me a newbie, I have just managed to get my BoeBot running around the living room using its IR sensors to avoid any obstacles it may encounter, great stuff and congrats to Parallax on superb documentation.
OK so now we turn to the Great Outdoors, Summer is coming and I would like to swop out the living room for the back yard. The plan to transplant my BOE board onto a platform equipped with knobbly all terrain tires, and two dc motors, a larger battery pack and off we go...
Well I know that is not quite that easy, and I realize that I would need to invest in a motor controller to handle the two DC motors. but would the IR sensors still work OK, would I need to return to 'whiskers' how much extra work is involved and what pitfalls can I expect to encounter? Can/Should I just start my swopping out my servos for DC motors and work from there. I am hoping that those of you with experience in such matters could help me set my goals with any advice along the way. OK I am trying to avoid obvious mistakes that could so easily be avoided by just 'asking'.
I have looked at the variety of speed controllers available but would prefer to stick with Parallax associated products because I know that somewhere there is code and advice available and as a newbie I find that aspect of staying within the Parallax family a great help and a valuable resource.
Regards Nigel
Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Regards Nigel
Winston Churchill
·· There are, of course, any number of roads you can take here (No pun intended).· Basically you could make the decision based on the type of terrain you expect to traverse.· We do have the Tank Tread mod, which works nicely outside, just not in tall grass (Even some short grass).· You can add a Memsic Accelerometer for tilt detection, etc.
·· If you decide you need more speed and bigger wheels, then yes, a motor controller is in order, but you won't be able to choose until you find suitable motors and know their requirements.
·· As for the IR detection.· It will probably have to be slightly adjusted based on the height of the Bot and what type of terrain you expect.· You could also mix sensors.· Or, add a PING sensor.· Then the IR could be used solely for lower object/edge detection.
csavage@parallax.com
·· I think the IR sensors could still be used aimed down for edge detection, or, at a lower level for close-up object detection below the line-of-sight of the sonar.· I will have to try this in practice, but I would imagine the usefulness would go down, but I wouldn't think to zero.· I could be wrong though, my bots have yet to see outdoors.· I will be trying soon now that I am in better weather.· It's still several feet of snow in my old neighborhood!
If I wanted to run more than two motors say 4 or 6 could I link them in parallel and run them that way?
As for the Ultrasonic would the new Ping))) Ultrasonic from Parallax work and would I need one or two or more?
Thanks again guys, I really appreciate the help.
Regards Nigel
Winston Churchill
Paul,
Have you tested this? I was under the impression that the reason we modulated the IR signal(~38khz) was because we needed to eliminate interference from, among other sources, sunlight. Most remote controls work well in sunlight and I wonder what your source was for this information.
good luck!
daniel woolston
Teksystems Inc.
www.danwoolston.com
·· At 5 for $100.00 you could afford to mount one on each side, and still have an extra for another project.· Perhaps a garage parking indicator...
WRT the motors, those sound strong enough for your application.
I take the point that daniel woolston made about the BoE Bot trailing ball, and in order to rectify that I would like to add another two wheels giving me a 4WD base, but the motors I had marked for use have a 200mA draw with a stall rate of 3.80A so If I equip my platform/base with two motors on each side wired in parallel that would give me a stall rate of 7.6A checking through the stats there doesn't seem to be a motor driver that can handle that much. Is there another driver or alternate option other than running four individual driver/motors. I am willing to make a custrom H Bridge but would need a good schematic and directions. Any ideas!!
Regards Nigel
Winston Churchill
VK
