Matrix Keypad Conversion
I've been looking to interface a BS2 with a piece of equipment containing a matrix keypad. My intentions are to disconnect the keypad and automate the button sequence. Has anyone done this before? I first thought that a simple transistor would work but found that it would hang the matrix. My next step is reed relays, I think this will work but they are fairly big and probably not the most reliable. Is there anything else on the market that would work?
··········· The easiest way would be to simulate the signal. Which should be a high or a·low? Once that is found you could use a few 74595 to simulate that signal. With this setup you would need to have common ground to the circuit.
Stephen Swanson
Technical Support
sswanson@parallax.com
Are there any BS2 specific documents using the 74HC595? I see they are sold on this site.
Took a quick look at the Nuts and Volts section but turned up nothing.
I googled the datasheet but have yet to figure out exactly what all is involved.
BTW, I should add that this matrix has a total of five keys. Four of these are on one matrix and the fifth is on its own. The reason for the fifth key being alone is due to a feature that requires two buttons to be pressed at the same time.
""""""" Found the 595 thread at the bottom of the page. Thanks for your help! I will get a couple ordered and go from there """"""""
Post Edited (Eric R) : 4/12/2005 12:42:04 AM GMT
Jon Williams
Dallas, TX· USA
·· Not sure how much of a matrix you have with 5 keys, one being isolated, but if you know how many lines there are, and which lines are shorted together for each keypress, it shouldn't be too hard.· With so few keys I can't help but wonder if another solution might be in order.· How many wires attach to the keypad again?
csavage@parallax.com
This IC was new to me, I should have consulted the help file first.
Chris,
There are six wires total
Power (two wires total)
1,2,3 and 4 share the same +5vdc
5 has its own·+5vdc
Return (Four wires total)
1,2 and 3 have their own return line
4 and 5 share a common return··line
I assume this follows the matrix system. I know for a fact that at least 1 and 5 can be pressed at the same time. This should also hold true for 1 and 5, 2 and 5, and 3 and 5.
If a transistor is installed in place of a key it will work, however, if two or more transistors are installed the system locks and will not allow entry. I should mention that this keypad has a rubber front with either a conductive rubber pad or carbon contact pad much like a nintendo controller. I mention this since there may be a impedance or maybe a capacitance issue? I don't know. This is why my next step was reed relays so there was no "drag" on the bus. There must be a better solution that I am not aware of and the 595 may work.
I tried to draw a picture of your 2 matrices, and everything was fine until I ran into the following: "4 and 5 share a common return line". That seems a bit odd, as either a 4 or 5 would be able to act as the "shift" key. This may be unique to this installtion however, and a pre-planned part of the circuit. I guess you could say it's just not ordinary or usual in my experience.
It DOES fit with your additional comment from above: "I assume this follows the matrix system. I know for a fact that at least 1 and 5 can be pressed at the same time. This should also hold true for 1 and 5, 2 and 5, and 3 and 5." so you may well be correct in your analysis.
The following is purely a guess, but it may have some merit. I suspect you will continue to have a problem with "hanging the matrix" until you use a method which provides a very momentary keypress "pulse" of the activated keys. I mean that in terms of fast duration and not anything frequency oriented. In the industry this is called make-then-break action, as opposed to momentary action. You may be able to simulate this with a latch IC rather than a serial to parallel register ('595). With an appropriate latch, the outputs can be set ahead of time, and then you can pulse ("blip") the output bus enable line. Just a thought if the '595 appears to cause the same "hang" problem as the transistor solution.
Bruce Bates
