BS2 and x10 hardware
I am working with the BS2 and the x10 Two-Way Power Line Interface (TW523).· I know that Parallax has a code called XOUT that is used to send signals to different appliance modules using the TW523.· I am trying to use an EagleEye motion sensor, and I want to use the TW523 to receive a signal from the motion sensor (if possible) and then in turn turn on an appliance module or lamp module to alert that something has tripped the
motion sensor.
Are there any code functions that are similar to the XOUT command that enable the BS2 to input signals from other devices, or does this experiment require a higher level of programming.
motion sensor.
·· While there is no equivalent command to do what you want, I believe there is a device available that does bi-directional communication and is serial controlled.· So you could SERIN/SEROUT to it.· I think it's called, "Firecracker" or something to that effect.· I believe you can get it right from X10.com.
csavage@parallax.com
There is another X10 interface that uses real RS-232, however, and the BS2 should be able to connect to it. It will send a set of bytes to the BS2 whenever any command is sent on the power-lines -- by X10 switch or X10 monitor. You would use SERIN/SEROUT to communicate with this unit -- I think it's called a 'home-controller'.
OK, found it: http://www.x10.com/automation/x10_ck11a.htm
This is their 'standard' home automation product for $50.· For $100 you can get an additional package.· The house wiring interface is their CK11 -- which has an RS232 output.·
Apparently, they have a new HomeControl Pro system, using a CM15 -- which is USB based.· Your BS2 can easily do RS232 -- it cannot do USB.· Go for the link above.
P.S. Still searching -- there does exist the 'PowerLinc' -- http://www.smarthome.com/1132b.html
P.P.S Aha!· I found the CM11 -- which is the RS-232 based bi-directional unit: http://www.smarthome.com/1140.html· -- And THIS page even includes documentation and serial protocol!
Post Edited (allanlane5) : 4/11/2005 9:04:05 PM GMT
Very robust, very simple. But it is uni-directional -- 'Send' from the Bs2 through the Firecracker to the house modules only.
For bi-directional use, the CM11 looks to be the easiest and most straightforward for a BS2 to work with. "ActiveHome" 'standard' unit is the CM11 -- the 'Pro' unit, CM15, is USB based, and so can't interface with a BS2.
X10 is fun.
Harry
