I2C control of A/D devices (or controlling other I2C devices)
I need some help on better understanding Basic Stamp’s I2C control.· Specifically, I am planning to control a Philips PCF8591 8-bit A/D device.
(http://www.semiconductors.philips.com/acrobat_download/datasheets/PCF8591_6.pdf )
I noticed that Basic Stamp I2C protocol always sends the second byte as a WRITE (device “Address”[noparse];)[/noparse], when I do a I2C READ command (“I2CIN”[noparse];)[/noparse].
Trying to READ the PCF8591 (and presumably some other I2C devices) causes the slave device to start sending its data to the master starting with the second byte.· (ref: page 9 of above pdf link)
Does this conflict with the Basic Stamp sending a WRITE on the second byte (while the slave is sending a WRITE)?
Does someone have successful experience in controlling the PCF8591, or possibly other I2C A/D’s such as Microchip MCP3021 or Maxim MAX1362.
Any help would be appreciated.
Jim S.
Jim S.
And please post your code if you can.
I've implemented IIC using Parallax code·with an EEPROM and a SRF10, and the routines were pretty much the same.
Post Edited (Jonb) : 4/11/2005 12:57:33 PM GMT
I have not coded yet.· I noticed your attached code "bit-bangs" the I2C function.· I plan to use the BS2p that has the I2CIN and I2COUT commands (I want to do it the "lazy" way).· If for some reason I am not able to use the I2CIN/I2COUT commnads, then I'll resort to bit-banging SDA and SCL signals and your sample code will be useful.
Still hoping for someone to shed light on my original question.
Jim S.
The code was taken here: http://www.parallax.com/dl/docs/books/sw/exp/sw32.pdf
I'm sure someone from Parallax will answer your question, but in the meantime there is alot of info by doing a search for "I2CIN".
Post Edited (Jonb) : 4/11/2005 1:37:34 PM GMT
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 4/11/2005 1:59:09 PM GMT
Does this mean that the BS2px is now officially released? And a new version of the IDE to support it?
Jim, in the I2CIN command on the address bytes after the device ID are both optional. The program Jon posted illustrates this, where it reads the "dummy" byte right after sending the device ID. I think I recall that some of the first BS2p chips, version 1.0, did automatically want to send an address byte, so you might find some literature out there still that says that. Look at the current help file and you will see that they are both optional.
Tracy Allen
www.emesystems.com
Jon Williams
Dallas, TX· USA
Thanks for clarifications.· You have given me the confidence so that I can proceed with my pcb design.
Still little unclear·why "dummy" byte would not cause a conflict.· Once I am ready to test, I'm certain I'll figure it out.
Jim S.
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 4/11/2005 5:14:06 PM GMT
Perhaps I am missing something else here. When I referred to the “conflict” in my last post, I was referring to the fact that (as shown in the Philips “A/D conversion sequence” timing diagram) the second byte (following the ID address and shown as “transmission of previously converted byte”[noparse];)[/noparse] is a WRITE from slave to master, and will therefore conflict with the Basic Stamp second byte which is also a WRITE, but from master to slave, thus to me, it seems that both devices will “talk” on SDA line at the same time. Regardless, I do understand that this “dummy” reading will be discarded.
Jim
What second byte from the Stamp are you referring to? Here is Jon's syntax...
I2CIN SDA, PCF8591, [noparse][[/noparse]dummy, STR aIn\4]
The only byte sent from the Stamp is the device ID held in the variable PCF8591. Then the I2C command turns around to receive the dummy byte followed by the 4 conversion results from 4 analog channels.
The I2COUT command sends two bytes after the device ID, one to configure the chip and one to set the analog D/A output level.
I2COUT SDA, PCF8591, [noparse][[/noparse]D2A_Enable + Auto_Inc, aOut]
Tracy Allen
www.emesystems.com
I2CIN Pin, SlaveID, Address {LowAddress}, [noparse][[/noparse]InputData]
Address: is a variable/constant/expression indicating the desired address within the I2Cchip to receive data from…
What the above means to me is that the "Address" (second byte following SlaveID) is a WRITE from Basic Stamp to slave device. This also implies that the "dummy" byte ( I2CIN SDA, PCF8591, [noparse][[/noparse]dummy, STR aIn\4] ) is a WRITE from Basic Stamp to slave device (not vice-versa as you’re indicating).
Again, I don’t mean to dwell on it, but I still think this causes both devices to "talk" on SDA line at the same time.
"Address is an optional variable/constant/expression (0 – 255) ..."
where the watchword is "optional". Observe Jon's syntax, which in fact not send an address after the device ID. Only one byte, not two, was sent from the Stamp to the PCF8591.
The I2C command on the Stamp did evolve from its earliest implementation so that it could handle a wider variety of I2C devices. Notice that the top sticky message on this BASIC Stamp list is where you can download the most recent and up to date HELP file, courtesy of Jon Williams!
Tracy Allen
www.emesystems.com
Jon Williams
Dallas, TX· USA
Ah-ha! I finally get it! (Jim, can you say it three times - optional, optional,·optional).
Thanks for your patience and perseverence with me.
