Don't hurt your stamp
Unfortunately due to user error, stamps can sometimes be damaged when attempting to drive a load. This seems to crop up every few weeks.
In that regard check out the attachments below.
The file names should be self explanetory.
plus i don't use a 100k that leads to signal degredation i use a 10k.
-~Kill~-
and in my case i think a 100k lets the input float too much 10k ties it down really well.
-~Kill~-
If you are not aware, you can edit your own posts. To access this feature click on the icon of a pencil in the upper right corner of your post.....FYI.
Post Edited (KenM) : 4/10/2005 3:51:12 PM GMT
With the BS2SX the command is:
FREQOUT PIN, 1, 15000
Then there is a 10 to 20 msec delay before I repeat the sensing.
Once I tried to reduce the delay between sensing to less than 10 msec and smoked the Stamp pin (actually, five pins for five IR LEDs).
I assumed that at 37.5 kHz, the capacitance of the FET gate was loading the Stamp pin too much.
Comments?
Rick
