Need help regarding a relay switch . . .
                    I do not have a strong background in electronics so I need some help.  I want to use the Basic Stamp (with the BOE) to control a large servo.  However, the servo requires more power than the Stamp can provide.  I need the Stamp to control a switch that would be connected between the servo and auxillary battery.  For example, if I wanted the servo to be on, the Stamp would turn the switch on and allow power to servo.  From what I have been advised is that I need a relay switch that operates using an LED rather than a magnet and coil.  If anyone has any idea about what I am talking about and give me any advice I would really appreciate it.  Thank you.
Post Edited (Jonb) : 4/9/2005 11:16:48 PM GMT
This assumes the "Servo" you are talking about is a typical air-plane model control servo, which uses a pulse of 1 to 2 mSec width, repeated every 20 mSec, to control its movement.
If you're talking about some other kind of "servo", then this may not apply. It has three wires, right?
Sorry if these questions sound stupid. Thanks again for the advice, wish I knew about this forum a week ago.
Post Edited (Jonb) : 4/10/2005 1:28:59 AM GMT
So the BS2 should be able to treat the Servo as just another digital output, which gets the above pulse signal to control it. All the power devices should be inside the Servo, being controlled by the Servo comparator. You only need the common ground so the Servo can properly read the BS2 control signal.
If you are really concerned, you should be able to put a 470 ohm resistor in series in the control signal between the BS2 and the Servo to limit any 'disaster' current -- but it shouldn't be needed.
