V2Xe compass module from PNI
Hello, for a good number of years now, I have been working with the Stamp and the regular V2X compass module.· I now find that I need more accuracy that the V2Xe compass module offers.· I have down loaded the code from PNI that uses the BS2p stamp.·
Question:· Does anyone know if I can use the V2Xe compass module with a BS2 stamp.· I don't have any BS2p stamps, but I have lots of BS2's.
Deno
Deno
Try this link:· http://forums.parallax.com/showthread.php?p=468398·.· This may help you with your project.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
I think it should. I have been playing with a V2XE this week, although with a 2P, not a 2. I may try a 2 over the weekend if I have time.
If you have any odd results when trying, look for another thread about the 2XE earlier this week, with a title "Shiftout-Mac and PC editor different?". There is an anomly with the code wherin some users have to change the stock code to get it to work, I did.
HTH,
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Now, I would like to use the V2Xe compass module because of it's increase accuracy...(tenth of a degree resolution), but I would like to know if the BS2 stamp is fast enough or has the right commands to control the V2Xe compass module. I know the BS2p will work with the V2Xe compass module, but will the BS2 work as well?
I think the conversion from floating point to integer could be simplified (made faster). This was a topic of a thread last year:
groups.yahoo.com/group/basicstamps/message/45030
groups.yahoo.com/group/basicstamps/message/45041
Tracy Allen
www.emesystems.com
Jon Williams
Dallas, TX· USA
deno
Just to make sure you know, the 2XE needs a 3V power supply. PNI states there will be no problem between the Stamps 5V TTL and the 2XE 3V on the output/inputs. I put a 220 ohm resistor in series just in case.
Jonathan
deno
