URGENT!!!!!!!!!!! stamp problems
My basic stamp has been working fine for months.· Today, the day before a robotics competition, the stamp will not download my program and seems to be getting warm.· I have fresh batteries, but still no download.· It's not the board because I tried a lesser stamp and it downloads fine.· I need the first stamp because its memory capabilities. Any help would be appreicated.
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
You mentioned fresh batteries.. 9volts? Anychance you touched them backwards by accident?
Do you have another board to test the stamp in? OR can you remove your external cctry from the board to test the stamp?!
Check the schematic for your board/stamp and measure some voltages and let us know what you have.
Steve
HAve you gone along the stamp pins and measured voltages?
That 'start' line probably would only kill that particular pin. But maybe it's bringing a bunch of noise down the line....I'd assume not!
IS this a serial stamp? Is your cable any different?
Does the Loopback/echo status lines come up ok? Do an Identify Stamp out of the PBasic menu....
I'm off to run errands...I'm sure someone more knowledgable will jump in for me! [noparse];)[/noparse]
good luck
Steve
serial. normal serial cable transfer.
Lacking some voltages at several pins.
getting hot fast.
Jon Williams
Dallas, TX· USA
You can contact our sales department at 1-888-997-8267 and ask for an RMA # and this will allow us to test it.· It has the indications of being in thermal runaway.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
We flew in on thursday evening with airtran. Today when we were going to test run our robot for qualifications, the motors were not moving. The motors are connected to the PWMPAL. We tried reloading the code 3 times and the 4th time the code will not load any more.
The chip is very hot to the touch. Hot enough to burn you if you touch it for too long. This is a strange irony that two people are at a robotics competition are both having the same problem.
We have tried using 5 or 6 different types of batteries. We use a 7805 regulator to control the voltage going into the stamp. We measured the current into the stamp and it read over 100 ma ... really about 150 to 200 ma with no external circuitry connected.
THe robot was transported as carry on. We do not thinkthe xray machines had anything to do with it.
So thats our problem. THought it was funny to find some1 with the same exact problem.
It's interesting that one of the stamps of lesser capacity survived.
Beau Schwabe - Mask Designer III
National Semiconductor Corporation
Latest Company News
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
Dave
Dave Andreae
Tech Support
www.parallax.com
your stamp has probably been serving you well and has died from pulling alot of current and normal wear and tear
-~Kill~-
Jon Williams
Dallas, TX· USA
I would think plugging the BS2 into conducting foam would help. It would give a place for any static charges built up by x-ray exposure some place to go before they could damage the BS2.
Or I could be completely off-base with this one. It just seemed strange that two BS2's at the same competition would die in lock-up on the same day. As Jon has said, usually the BS2 architecture is extreemely reliable and robust.
