3 or 4 axis cnc stepper controller
·Hello again to a very helpful community,·I am a newbie to the stamp world and I would like to build a·4 axis stepper motor controller. To control a 4 axis cnc router gantry that I am building as well.
I was reading the specs on the Little Step U Controller and it seems to have a lot of the features that are in some of the more popular OEM controllers. And it will handle up to 3 amps/phase for each stepper motor.
What would be the best model of Basic Stamp to use in this application? And how does the Little Step interface to the stamp?
I would like to be able to use Solid State Relays to protect the stamp hardware and would also like to have various Proximity Sensors·for homing\initial cycle etc. I can certainly see that 16 I/O is enough for the various sensors that I would like to incorporate into this controller.
Has there been a similiar application created in the Stamp Community? And if so is there source code available to experiment with?
Would each Little Step U require a seperate power supply? and if so is that a better way to supply power than one common larger supply? I would like to build a reliable controller that might incorporate designs that I may not be familiar with.
Sincerely,
Colin Morris
