DTMF FIgure 5.3 in Basic Stamp Relay question ?????
When using the figure 5.3 from the basic Stamp manual it shows how to interface the controller to the phone line. RIght before you connect it to the phone line the figure shows to use 'connect switch or relay contacts'.· What I want to do is have· the contacts always open and when the phone call is to be made it closes to make the phone call for a certain time.· What will be the best way to accomplish this??· WHich relays would we need ???
THanks
THanks
For the relay you will want to use a DTST-NO (double poll, single throw, normal open). www. Jameco.com part#138456CC. To control the relay with the Basic stamp you will use the doc at http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv6.pdf.
Stephen Swanson
Technical Support
sswanson@parallax.com
I got the correct relay, how do i power up the relay.· The pin that is sending the DTMF info is only outputting aout 2volts.· I need atleast 5V.· Is there a way to make the pin output higher voltage and still be able to dial the numbers.· or do i use another pin, and if so how do i make it output 5 v.· OR would i have to amplify the pin output.
Post Edited (stbrnrd) : 4/15/2005 3:53:42 AM GMT
