BS2 to BS2p conversion (esp. for PULSOUT)
Hello all, is there an exact conversion rate for PULSOUT commands and suchlike? I know it's approx 2.5 but I have some very sensitive PULSOUT values because the servo speeds are not the same. Also because I need exact speeds, and it would be a pain in the butt to do 100 PULSOUT calculations all over again. I don't even know max and min speeds for the BS2p! Help, please?
·· Why would you have to do 100 calculations?· Once you calculate for the center position, you can use an offset value for the forward and backward values.· Or, calculate one extreme and the other, and use that range.· I may be missing what you're trying to say, but it sounds like you're over complicating it.
·· How many values are you currently using for the BS2 code?
csavage@parallax.com
#SELECT $STAMP #CASE BS2, BS2E, BS2PE Scale CON 500 ' to ms for 2 us per unit #CASE BS2SX, BS2P Scale CON 1250 ' to ms for 0.8 us per unit #ENDSELECT Flash CON 25 * Scale ' 25 millisecondsIf you want to do it all manually divide your pulse width (in microseconds) by 0.8.
Jon Williams
Dallas, TX· USA
