Parallel LCD
I got a parallel LCD going using code I copied from “Exploring the SX Microcontroller with Assembly and BASIC Programming • Page 145" problem is, it only works when run through the debug. When I load it using the program button nothing happens.
·· Posting your code might help.· But it sounds like it might be a timing issue.· Like perhaps you are sending the data too fast.· Without seeing your code I can't tell whether you're handling it or not, but for each command/character you send to the display, it sets a busy flag, and if you blindly send data without checking it, you can over-run the LCDs ability to receive and process the information you're sending.
csavage@parallax.com
Have you verified that your system is working properly when you program? After doing a Run->Program, the SXKey no longer provides a clock. Have you removed the SXKey from the system and replaced your clock source?
Thanks, PeterM
The problem was, I didn’t put the resonator in. This is probably mentioned in the manuals, but I must have missed it. Thanks again.
Ed Nowak
